help! axle ?
Old Sep 22, 2002 | 09:20 PM
253EK's Avatar
Default help! axle ?
wussup everyone, i have a 94 rs and was wondering if i can use ls/gsr/type r axles cause i dont have abs. my right side axel is broken and the left side needs new boots, i have 140,000 miles so i might as well change them. need your help and opinions. im planning on going turbo or ls/vtec so i was thinking i need stronger axles, what do u guys think? where should i go to get axles?
thanks
Old Sep 23, 2002 | 07:47 AM
Full Race EG's Avatar
Default Re: help! axle ? (darren94rs)
Just go to your local import parts store and ask for axles for a 94 RS without ABS. You dont need to get ITR or GSR axles for a RS. Just go with the stock axles for your car and you will be happy.
Old Sep 23, 2002 | 08:02 AM
carl_aka_carlos's Avatar
Default Re: help! axle ? (IntegraLStuner)
or you can go to driveshaftshop.com and get some of their axles. I got their stage 2's for my 94 RS (which will be way overkill b/c my car won't ever make enough power to break em) for 200 bux
Old Sep 23, 2002 | 03:03 PM
PnX-R's Avatar
I've been told that the passanger side front axle is interchangeable between the non-ABS 90-93 integras and 94-97 (i believe those are the years) non-ABS integras.. So what you can do is, call Acura and ask for the part number for an axle for a 2nd gen teg and a 3rd gen teg.
coquieg6
May 3, 2011 07:14 PM
NsX_CrX
Feb 5, 2007 07:50 AM
BlackNoise
Feb 10, 2004 10:26 AM
92TypeR
Aug 20, 2002 05:41 PM
