ef sedan b16 swap power sterring trouble
Old Dec 8, 2010 | 08:38 PM
jessedm's Avatar
Default ef sedan b16 swap power sterring trouble
had some questions on a b16 swap i know almost all the stuff that i need to do in order to make this swap work but my sedan has power steering will the lines my car have fit a b series power steering pump or will i have to convert to manual rack and pinon and if so do all civic crx years fit rack and pinion wise?
Old Dec 8, 2010 | 10:29 PM
hybridmiklo's Avatar
Default Re: ef sedan b16 swap power sterring trouble
I tried to keep the power steering in my sedan when I put in my b20. But the fitting from a b series pump is different than the sedan power steering hose and won't work. I even tried a b18 pump and doesn't work.
I had to reloop the rack.
Old Dec 10, 2010 | 12:39 AM
jessedm's Avatar
really i thought it was possible to keep it with a b series swap whats harder/more costly swapping out the rack or finding a solution to keep my power sterring that really is gonna suck to do
Old Dec 10, 2010 | 01:56 AM
Nooch's Avatar
dont want to go without any power steering? isn't that **** all the rage now-a-days?
Old Dec 10, 2010 | 08:44 AM
jessedm's Avatar
would anyone know
Old Dec 11, 2010 | 01:27 PM
choocko's Avatar
I'm having a similar problem. My buddy told me to take in in to a hydrolic shop and have them make hose fitting for the pump. you can give that a try.
Old Dec 12, 2010 | 03:15 PM
jessedm's Avatar
ya ok i so thought there was a solution to this other than that mayby ill just get a manual rack hmmmm
Old Dec 12, 2010 | 06:15 PM
hatchet_honda's Avatar
youll have to use the b series power steering pump and have a custom fluid line made. orrr ive seen ppl use AN adapters and run a SS braided line from the pump to the rack. earls plumbing makes the fittings. or aeroquip
http://www.summitracing.com/search/?...0fitting&dds=1
heres just an option
Old Dec 14, 2010 | 09:23 AM
jessedm's Avatar
hey thanks for the tip but i guess im just going to go with a munual rack im not all that good at making stuff fit i wanna do things the way everyone before me has done it so i may still get help in the future
_Keith_
Apr 5, 2009 09:53 AM
b16ekinva
Oct 23, 2008 05:23 PM
freakystyley_73
Mar 5, 2007 06:17 PM
Ransom
Feb 19, 2004 01:32 PM
crxwanted
19
Apr 26, 2002 09:45 AM
