Transmission & Drivetrain Gearboxes, Differentials, Clutches
Grinding into gear, abrupt clutch release, whirring noise.
Old Dec 8, 2010 | 03:41 PM
HondaRcB's Avatar
Default Grinding into gear, abrupt clutch release, whirring noise.
So I'm having some clutch/transmission issues with my 95 GS-R. It started a few weeks ago where it would occasionally grind going into 2nd/3rd gear. It has gotten worse, seemingly with the cold weather, and now grinds 80% of the time going into 2-5th gears. It won't go into gear unless I double clutch and then catch the revs on the way down. If coasting at a low speed with the car in gear but the clutch depressed it often makes a whirring noise until I put it into neutral, or release the clutch. It also seems to make a squeak when depressing the clutch at the point nearing fully depressed.
I'm going to try new MTF, master and slave cylinder this weekend. I'm hoping this fixes the problem and I don't have to drop the tranny for the TB/clutch.
Thoughts?
Thanks guys.
jrhcivak
17
Apr 11, 2012 03:55 PM
Bizzle5OH3
May 13, 2011 03:05 PM
CAVTECSol
Mar 29, 2011 12:53 PM
Tim2179
Mar 25, 2008 08:39 PM
integra81
Mar 11, 2002 07:43 AM
