Why is my AFR reading all weird in Neptune?
Tuning Program: Neptune RTP
Wideband: Innovate Lc-1
Question is why does my AFR jump to weird *** numbers. On my display gauge it only reads up to 21 when the car has no load and coasting. Which is indicated by 0.1 on Neptune but every datalog I will get some awkward numbers going up to 30 on NEPTUNE. Is this normal with an lc-1? Or is my something being retarded?
Heres a video to explain what I'm saying.
http://www.youtube.com/watch?v=MzE3zGs9t30
Firstly, the video is private so we can't watch.
Secondly, you haven't mentioned what method you have the LC-1 connected to NepTune with. If it's Direct Serial, NepTune shows what it receives from the unit. I don't cap it at a certain a/f, which is probably what the gauge is doing. It does send some ridiculous numbers when there's no fuel (In decel or with the car off). Nothing to worry about.
There you go. It doesn't matter what it shows during free air or decel as long as it's showing you the correct a/f during operational parameters. That's just the a/f value the Innovate outputs during those periods and I don't skew or limit the values that come in.
Thats what I thought, but from time to time during cruise it will also do it. Doesn't bother me too much, just wanted to make sure its normal.
Thanks for the verification JR
No problem. Keep me posted and send me a log if it does it during normal operation. If it's sending erroneous data here and there then I will limit it to keep that out.
http://www.youtube.com/watch?v=S8VXzOgsR8c
Before I went out to datalog Neptune had a new version so i updated it. Dont know if JR already made new adjustments or not but the freeway cruise seemed to be better. More solid numbers only time it read all weird was when there was no load which you should see at the beginning of the video.
I'll try city driving tommorow again just for my own reference.
Alright so I did a little city datalog. Its not horrible it just annoys me.
My laptop is daily used for school also, so of course it wont be as fast.
http://www.youtube.com/watch?v=h-w6PDFikyY
I up the data logging speed almost to its max. Its always been this way ever since I purchased NepTune.
Then your computer must be really really slow or you don't have the right drivers for the laptop installed. Even my 2000 model year P4 1.7 datalogs better than that.
My computer works fine like any other. But we'll see. Maybe a little update might not hurt. I purchased it right before windows 7 came out. Only a year ago
are you running any larger background programs? I've never had to close any programs from the task manager but maybe you have something running that doesnt need to be running.
tried disk defrag? cleanup? anti-virus?
I actually uninstalled a lot of programs I do not use on my laptop. Its running alot faster now. I will upload just to confirm later. Accidentally deleted my wideband usb adapter so have to reinstall it again.
hillbillycivic
Sep 27, 2012 12:08 PM
IggDawg
Feb 8, 2004 04:06 PM
