CLUTCH WON'T ENGAGE
Hi everyone, i just got finised doing a auto to manual swap on a 94 4 door civic. We had gotten everything finished up and upon start up it wouldn't move!!!the clutch pedel has very little pressure but some, it also shifts into every gear just fine but when you go to dissangage the clutch to move nothin happens.... you can get compleatly off the pedel in GEAR and rev the engine the speed sensor is working because the spedo on the gauge cluster climbs. The swap came from HMO and seemed to be in great condition as always, everything went together smooth and i'm just stuck. If anyone can help or ever heard of such a thing any advice would be much appreciated.. ive blead the clutch over and over, checked for any leaks externaley and dont see any, like i said it has some presure goes in to any gear but wont move. i noticed i get some fish bubbles from the master cyl while bleeding.
i am having the same problem on a different application.. sorry i can't be of any help but i'm in for answers...
Mine is a 2003 accord v6 6sp... driving on highway and all of a sudden it was like someone put it in neutral. Same thing- goes into gear running w/o clutch peddle engaged, and vss registers.
thinking either clutch or diff.
kidrolla
Nov 18, 2006 11:24 AM
