FS S2K THROTTLE BODY,EURO-R SINGLE ROW CRANK PULLEY AND MORE
SKUNK2 PRO1 CAMS FOR H22A, ONLY 200 MILES ON THEM 400$
F2OB SIR-T VTEC HEAD, FULLY RECONDITION 300$
SELLING S2K TB, 65MM TAPERED TO 62MM, 200$ COMPLETE WITH TPS AND MAP
DH-RACING 74MM TAPERED 68MM TB POLISHED, 150$ COMPLETE WITH MAP AND TPS
F20B SIR-T 310CC OBD2 INJECTOR 100$
F20B SIR-T VALVE COVER, BOUGHT BRAND NEW FOR HMO FOR 175 SHIPPED,
I USED IT ON MY H22 FOR 5K. ALMOST NO FLAWS, A FEW CHIPS BUT THATS ALL, ASKING 100$ OBO
OBD2 8PIN H22/H23A/F20B DISTRIBUTOR, ALMOST BRAND NEW, COMES WITH WIRES, 100$
INTEGRA/CIVIC B18/B16 HYDRO TRANS COMPETITION CLUTCH DISC, 6 PUCK SPRUNG, 500 MILES ON DISC 80$
H22 LOWER AND UPPER TIMING BELT COVER, 20 EACH
F20B DOHC VTEC BLUETOP TIMING BELT #14400-PCB-004 BARELY USED 3000 MILES ON IT, 80$ PAID 150 FOR IT
H22 TIMING BELT OEM HONDA BARELY USED 40$ # 14400-P13-014
H22A ALUMINUM PM5 AC COMPRESSOR BRACKET 40$
H22A POWER STEERING PUMP 60$
H22A AC COMPRESSOR 60$
H22A HYDRAULIC TIMING BELT TENSIONNER 20$
H22A OBD1 AND OBD2 ALTERNATOR, 50$
F20B OIL PAN, PICK UP AND WINDAGE TRAY, 100$ WILL FIT H22/H23
H22A OIL PUMP 75$
H22A OEM INTAKE MANIFOLD MAKE OFFER?
H22A/H23/F20B VTEC SPOOL VALVE AND SOLENOID 50$
H22A WATER PUMP 40$, BARELY USED
H22A OEM HEAD BOLTS, 20$ FOR SET, USED
F22A SOHC BARE BLOCK WITH MAINS 100$
B16/B18 M/T STARTER OEM 50$
B SERIES HYDRO INTERMEDIATE SHAFT 50$
I HAVE MORE PARTS,TEXT OR CALL 410-490-5301 IF INTERESTED OR WANT PICS OF ITEM
Last edited by Ashvin21; Feb 17, 2011 at 03:22 PM. Reason: ADDING F20B TIMING BELT
