tranny question
Ok my tranny has a code but I'm not sure if it is just there or if it is what tranny I have but it says ysk1. I'm missing a bracket for my clutch cable it is connected to the release arm but I have no tension here is a pic connected to the release arm but I can't find the bracket name pr part number
I can't figure out what I am missing
And I found online that inovated makes a b series throttle cable bracket should I order it I have tried a couple of brackets that are to short and I can't figure it out so I'm thinking about ordering it to try it. This is how I have it bolted but its to short and I can find out how to get it to work.
Thanks for the help these are the only things I need to figure out to finish my ls swap and be able to drive my car
http://www.hondaautomotiveparts.com/...CLUTCH+RELEASE
Nope, that just holds the wires for the reverse light switch. This is what he needs:
ah ha! yeah, for some reason, i couldn't find that parts listing.
Thanks guys I will check again cause I think I have the number 6 bracket but I was messing with it and I couldn't figure out how to get my clutch cable through the bracket but I could be doing it wrong so I will keep trying. I posted the pics cause I know how hard it is for people to say what there problem is and then it not be right so I posted pics thanks for the help
GSR_hatch936
Apr 14, 2009 04:41 PM
