what rims fit 27x10x15 hoosier slicks? on 93 civic
I am worried about choosing a rim with the right backspacing, i dont want it to rub on the knuckle.. i have the wide fendors so i am not worried about the fendors just on the inside.. Which rim dimensions would work best?
You might get better responses asking in the drag racing forum.
If I'm reading that size correctly (never used drag slicks), 27" in diameter is huge for a Civic and will be a problematic fitment no matter what size wheel is used.
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Rules
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.
bumsta217
Oct 5, 2006 04:16 PM
