crx died on highway
hey guys like the title says i was on the highway on my way home. then my crx started bogging and did't want go then died
tryed to get it to start back up but wouldn't.I looked at my ecu im was geting code 9 which is cylinder sensor right?. I checkd to see i was geting at sparks and i wasnt geting any. Thinking my dizzy died on me or could it be my main relay??
. I dont want to spend $175 on a new dizzy and find out it wasnt it
thanks guys for any help
i just had that same problem in my hatch. from what i have been told is to check your cam sensor or crank, i forgot which one.
check to see you are even getting voltage to the dizzy. i havent checked mine yet. so hopefully somebody can help us out??
no my rotor button screw didn't fall off inside the dizzy. i just had the module or what ever its called inside the dizzy tested and it was fine thought my msd baster broke but had it tested and it was fine. found a main relay hope it fixes it and its not my dizzy
theres a chip inside the dizzy it has the wires hooked up to it
should have 3 or 4 take off all 3 or 4 and remove the chip and go try one from a friends car or go to the junk and take a few
try them on and it might fix your problem
it's a 50 50 chance thou
also check to see if your timing belt is still on
it could of snapped off, you never know
i had them both tested and i took my external msd coil put it on my buddies car and it worked, i just bought a brand new main relay it's my dizzy that took a **** on me
If thers a autozone in your area they can test your ignitor
90si-rex
10
Sep 2, 2009 10:48 PM
i_VTEC
Oct 16, 2007 09:04 PM
sicegcivic
10
Mar 20, 2007 01:04 PM
