Basement clean out.
cleaning out the basement. Prices are negotiable but do not include shipping, I can provide shipping charges to buyer. PM me if you have any questions I will be updating this thread with more items as I get time.
Schroth Rallye Harness - A bit on the used side but still in good shape. Great for and autox car. $60
91 HF Honda CRX front sway bar. $60
Eibach 500lb springs. 7" tall with a 2.5" ID. $75 for the pair or Ill trade for a pair of 700lb springs of the same height and inside diameter.
Transmission from a 98 Civic LX - Transmission was in excellent condition when removed from car and has been sitting the basement ever since. $75 local pick preferred unless you want to pay the shipping.
Also an S20 Transmission from a 92 or 93 civic si. Transmission is in need of a little TLC, as I recall the input shaft bearing needs replaced. $50 again local pick up preferred but if you want to pay the shipping or make other arrangements please contact me.
Y8 bare block. Block is from a 98 civic ex coupe. Engine had 198,000 miles on it before it ate a rod bearing. block and girdle are in excellent condition and you can still see the hashing on all the cylinders. Only damage that was done was the crank got eaten up. I have the crank if you want it but its pretty much a boat anchor. $75 = Block, girdle and oil pan (crank if you want it). Shipping is that same as the transmissions.
set of four Dunlop Graspic OS-2's tires are 185/65/15 and mount on steelies that are 4x100. These tires are almost new I only drove on them for one winter, they probably only have 3000 miles on them if that. Tires have been stored in my basement and not seen the light of day since. Now Im tired of storing them and need to find them a new home. Would like to get $300 obo.
More is on the way. Thanks for looking and please buy something!!
-Roger
p.s. im located in RI
-Roger
I would like to sell them together. But I might have an extra one in my basement. Shoot me an offer, you may make me change my mind. Cash is a might good persuader
