d13 block with p08 head
Old Dec 6, 2010 | 09:20 AM
13line's Avatar
Default d13 block with p08 head
hi, i'm currently do this combo right now.
d13 block with p08 head.
just now i try to check piston to valve clearance.
with timing belt installed it is good when i turn the crank.
there is no sound valve hit the piston.
but if i set the piston to TDC and not installed timing belt valve hit piston (i think it's normal right??)
the problem now is why my timing belt can't be tight.
like the timing belt hv more 2 teeth..
so, which timing belt i must use for this combo???
can anyone help me??
i will post some pic later..
thx..
efjones9
Sep 1, 2010 07:56 PM
4doorcivic16
Apr 28, 2010 04:52 AM
project:JDM
Jul 20, 2009 10:14 PM
yrulkn@me
Jul 2, 2007 06:09 AM
Bevin
Aug 22, 2006 01:55 PM
