Anybody have a EQ underneath your cd player in your rex?
Does anybody have a EQ underneath your cd player in your rex? if so i need to know how you made that thing fit! did you have to cut some or what? thanx _Ben
i did it in my hatch. to make it fit you gotta get another ring that goes around the deck and then turn it upside down and then it will fit perfect in the place where the climate controls are.
in my crx i had one, just cut out the back of the pocket enough to clear the EQ, and mount something to the back so it won't move. i think i hot glued mine, never had a problem.
wow. sounds fancy. i would cut out the pocket to flush mount the front of the EQ, and use some hangars to bolt to the sides of the radio and EQ, similar to the way stock DUAL DINS are mounted to each other.
ilsoc
Audio / Security / Video
Jun 26, 2002 11:32 AM
