89 civic hatch rust bucket help
Old Dec 5, 2010 | 11:42 AM
Seanakins's Avatar
Default 89 civic hatch rust bucket help
So I have this civic and all four brake discs and drums were rusted. So i got integra 4 disc brakes to replace them. And i have the 40/40, a new mc and bb.
Well heres the issue I cant seem to get any of the parts off the car to put the new ones on. I've tried pb blaster and other liquids like atf and acetone on the rusted bolts and tried to impact them.
The rust is all over like all the parts like even the stock intake box bolts are rusted to the engine bay. Any suggestions on how to get these off or should i just give up on the car?
Thanks, and I'll get pictures up ASAP.
Old Dec 5, 2010 | 12:04 PM
sde780's Avatar
Default Re: 89 civic hatch rust bucket help
pb blast + heat
you using impact sockets with the impact wrench? 6 pt sockets are hard to strip
Old Dec 5, 2010 | 12:20 PM
Seanakins's Avatar
I'm using 6pt deep impact sockets. And pb blast + heat thanks I'll try that next.
Old Dec 24, 2010 | 06:52 PM
Seanakins's Avatar
so my brake lines in the bay and wheel areas are rusted and i want to replace them all do i have to use ss brake tubes or can i use braided ones there too? And anyone know if i can buy these at local stores or have to order online?
Old Dec 24, 2010 | 09:16 PM
Seanakins's Avatar
I also have a d16z6 head on a sohc zc block and a d15b2 complete in the car currently. I'm just going to take the d15 apart as I take it out any parts that I should keep for just in case reasons?
Old Dec 27, 2010 | 08:13 AM
90efb16als's Avatar
did you ever get those bolts or nuts off you were trying to get loose.
Old Jan 5, 2011 | 12:21 PM
Seanakins's Avatar
Not all of them. I cant get the top links of the rear trailing arms off the car. (The ones closest to the front of the car. )
And the bolts under the turn signals in the bumper, one side was so rusted the bolts just snapped. And the other side the bolts are stripped. Any ideas one removal without drilling?
Old Jan 5, 2011 | 12:26 PM
tonythetuner®'s Avatar
Bolt extractors they have spiral groves cut in side the sockets that dig in to the bolt head or nut. That wat I use to get striped bolts off
Old Jan 5, 2011 | 12:49 PM
Seanakins's Avatar
Thanks I'm going to get a set asap.
b20acura
Aug 30, 2011 06:03 PM
CrX-WoRlD
Feb 18, 2007 01:55 AM
Hatch1990SI
Apr 28, 2005 08:08 PM
maskedSONY
Jul 2, 2003 04:01 PM
all stock
Jun 28, 2003 04:19 PM
