body work help..
Old Dec 5, 2010 | 09:38 AM
Emmett316's Avatar
Default body work help..
where would i get quality rear quarter panels for a 90 crx?? mine is all bondo.
Old Dec 6, 2010 | 10:27 AM
ef4real's Avatar
Default Re: body work help..
find someone parting out a crx in your area and make them an offer. my .02
Old Dec 7, 2010 | 07:11 AM
jdmkid37's Avatar
Rustrepair.com has replacement OEM panels for reasonable prices. I was looking into replacing one of my quarters but instead. I cut all the rust out and used fiberglass,In all it turned out nice and feels stronger than the sheet metal that will probably end up rusting again as I live in the Midwest. It looks 10x better.
Old Dec 8, 2010 | 02:05 PM
Emmett316's Avatar
well mine was wrecked then bondo'd and i just want to change it before bondo starts falling off..
Old Dec 8, 2010 | 02:27 PM
jdmkid37's Avatar
Well in that case I guess you should get a patch panel. If I were you I would check out the condition of the rocker panels to make sure they aren't starting to deteriorate. Check underneath the car for holes and bubbles. I have heard of some kind of zinc coating that you can also use after replacement to slow the rusting process.
road2speed
12
Jun 23, 2010 05:33 PM
bmxbikes
Paint and Body
12
Mar 2, 2008 07:47 AM
kevin_
Oct 14, 2005 08:52 AM
bolduc89crx
16
Dec 11, 2004 04:42 AM
88crx Osaka
May 12, 2003 10:17 PM
