FS: 445whp/308tq 1988 Honda CRX Si
Old Dec 4, 2010 | 08:44 PM
wzywiec's Avatar
Default FS: 445whp/308tq 1988 Honda CRX Si
I'm selling my turbocharged LS/VTEC-swapped 1988 Honda CRX Si. I live in Washington, but I'm willing to go half on shipping costs if you live cross-country. Under the VIS USJDM carbon fiber hood is a B18 engine and cable transmission powered by a 57-trim Garrett turbocharger. The entire interior has been re-upholstered and I welded in new bolt holes and swapped the original seats with mint all dark gray (no stripe) Del Sol seats. The trunk has been rhino-lined and all intercooler pipes/valve cover have been powder-coated high-temp black. The interior lining and plastics are so mint it's ridiculous. The exterior has no dents or scratches, complete with original paint. No cracks in any windows or headlight/tail light covers, everything powered works, and I installed aftermarket speakers and a $300 Alpine deck. All brake drums, calipers, and ceramic pads are brand new. I also included below a list of aftermarket parts below:
AEM – gauges, wideband
Blackworks – coilovers
Blox – fuel pressure gauge, fuel pressure regulator, license plate frames, lower control arms, magnetic
drain plugs, oil sandwich plate, shift ****, throttle body, VTEC solenoid cover
CP – pistons
Distributor King – distributor
Duralast – brake pads, brake shoes
Eagle – rods
Edelbrock – intake manifold
Energy Suspension – shift linkage bushings
ETD – traction bar
Garrett – turbocharger
Golden Eagle – cam gears, fuel rail, head studs
Goodyear – vacuum hoses
Hooker – muffler
Innovative – engine mounts
MFactory – limited slip differential
Mishimoto – intercooler, intercooler piping adaptors, radiator, radiator hoses
Moroso – battery cables, oil pan
NGK – spark plug wires, spark plugs
Odyssey – battery
Painless – wire loom
Precision – fuel injectors
Portable Power Systems – battery mounting bracket
Power Garage – spark plug cover
Rota – wheels
Spal – radiator fan, relay
Sparco – pedals
Speed Factory – mounting brackets, oil catch can, radiator shroud, waste gate dump
Stinger – circuit breaker
Tial – blowoff valve, wastegate
Walbro – fuel pump
$8500 O.B.O.
Call/Text: 651-955-1746
I'm not interested in trades.
foxracer677
Jun 12, 2011 08:51 AM
JJtegfan14
Feb 17, 2010 11:43 AM
soon2beB00stedSOL
Apr 14, 2006 01:41 AM
DeDonDeRosa
Mar 16, 2005 06:17 AM
