FS: Dizzys, stock injectors, TB's, IC
Cleaning out my living room a bit, literally.
I have 2 spare distributors. One is a TD-46U the other is a TD-85U. Both are in working condition. The OBDII one has the bearing rattle (confirmed) but runs fine (drove around on it all summer). There is a thread on how to fix it. Does not effect operation. $50 each.
Bent Ebay intercooler. Fell onto jack at the track. Not a huge deal, still held boost fine. Would be good for a cheap project. Spray paint it black and no one will know. $30 + shipping
2 Sets of LS cams. One set has stock gears with it. $40 shipped for each pair.
I have a few spare LS blocks, heads and cranks along with most of the heads internals. Both blocks and crank are perfectly fine. Just need light cleaning / honing / machining to become usable again (obviously). Good to get sleeved or whatever!
$50 per crank. $30 per head. $50 per block. Dont really want to ship cranks or blocks due to weight so we'll have to work that out if needed. Heads will come bare with all parts in baggys. I cant reliably say I have every little piece so dont expect it.
CRX Radiator in good shape. Was running in my car until I got a water cooled turbo and had to step it up. Will fit fine in integras if you make a bracket on the lower support. $20 + shipping.
Stock Top hats. Pairs for both front and rear. $10 each.
OBX dual pod gauge cluster. Ran in my car. Fits good, but not OEM perfect. $25 shipped.
Blox TPS sensor. Couple months old, like new. Works fine. $25 shipped
Stock OBD1 throttle body with FITV. $25 Shipped
JG 65mm Throttle body. Has a slight chip off of the inlet. Wont effect anything. $100 shipped OBO
4 Stock Injectors. Will need new o-ring set ($6 at advanced autoparts). $35 shipped.
done
Mar 15, 2007 11:20 AM
GimpyAccord
Dec 20, 2005 03:33 PM
