Ideas please on how to machine a bushing...
Old Dec 3, 2010 | 06:58 PM
Jaker's Avatar
Default Ideas please on how to machine a bushing...
I have a custom made 27mm front sway bar for my RWD Civic Wagon, but I don't have the right bushings for it. The bar was made for me by Suspension Techniques in the exact same shape as the DA/EF front bar, but thicker at 27mm (DA bar is 24mm and EF is 22).
I'm trying this to attempt to alleviate the inside rear tire unloading through the Helical LSD that's back there due to too much weight transfer.
The chassis mount bushings supplied with the bar are the generic ones with the big D brackets, and I'd like to use the OEM D brackets, as the other 2 ST bars I have use them. I may use this for site specific tuning of the car (swapping sway bars).
What I've done is purchase a set of 19mm Energy Suspension EF bushings, but now I'd like some ideas on how to bore them out. Does anyone think they'd get hard enough for just drilling them out if I put them in the freezer overnight? What other ideas do you guys have?
Thanks,
Jacques
Old Dec 3, 2010 | 09:06 PM
weiRtech's Avatar
OG Fabricator
Default Re: Ideas please on how to machine a bushing...
just run the drill as fast as you can and feed it in a little bit at a time. spray some water on it with an old windex bottle or something to help keep it cool as you go. it shouldn't melt.
Old Dec 3, 2010 | 10:20 PM
LordAphotic's Avatar
with a good drill on fastest setting and a sharp drill bit it should work just fine ive drilled through all sorts of plastics before and never had any problem with it as long as the drill and drill bit are strong and sharp
Old Dec 3, 2010 | 10:39 PM
Jaker's Avatar
Sounds great guys. Now I just have to go drop the coin on a 27mm (1 1/16") drill bit ($$$$).
Thanks
Old Dec 4, 2010 | 12:10 AM
jere's Avatar
You might check with an ES dealer and try and find what you need pre made. The have thousands of styles of cars to choose from and they are usually only like $10 or so. I have re purposed bushings that where made for other cars a few times.
Unless you just want to add the bit to your tool collection
Old Dec 5, 2010 | 04:16 AM
weiRtech's Avatar
OG Fabricator
ship the bushings to me with your transfer case. i have a drill that size.
Old Dec 5, 2010 | 10:37 AM
Jaker's Avatar
Thanks for offering Aaron but I just bought one off ebay last night for $18 shipped. I figure however bad it might be (or good - Silver and Deming), it'll still be good enough for drilling polyurethane. I've also found that by slipping it into the metal chassis mount bracket, I should have no trouble holding the bushing while drilling on my small press or with my plugged in Makita drill, whichever one spins the fastest. Would some sort of oil/lubricant work as well as water, or would it be too slippery to let the drill bit cut properly?
Old Dec 6, 2010 | 05:47 AM
weiRtech's Avatar
OG Fabricator
it may not require any sort of cooling/lube when you drill it. after you drill it though, because the material is a little spongy, you may notice that the hole is a little undersize because it is springing back smaller after you pull the drill out. kinda like a vagina.
Old Dec 12, 2010 | 09:24 AM
lsturbo33's Avatar
You don't want to spin it as fast as you can! You want to spin it slow if your doing it with a hand drill. The faster it spins the more heat it creates causing plastics to melt without proper cooling.
Old Dec 12, 2010 | 09:47 AM
Linh.'s Avatar
Agreed but you can spin it fast and use air to cool it down. Don't spray any water on there. We machine a lot of delrin/teflon at work and always use air.
Old Dec 12, 2010 | 11:27 AM
Jaker's Avatar
Thanks guys. Delrin and teflon are a lot harder than the polyurethane that is commonly used in the Energy Suspension bushings. We'll see how it goes. I'm going to freeze them overnight before trying to drill, and I'll cool them with "something" while drilling.
Old Dec 12, 2010 | 07:30 PM
locash's Avatar
Jacques, if you decide on a harder compound, I could probably machine you something on my lathe.. Also, Silver and Deming used to be a brand name, but now it is what they refer to drills over 1/2" with a reduced 1/2" shank.
Old Dec 12, 2010 | 09:11 PM
Jaker's Avatar
Thanks Joe. If I have issues, I may take you up on your offer. Though the OEM bushings are "D" shaped.
Old Dec 18, 2010 | 10:56 AM
Jaker's Avatar
Well the drill thing didn't work out too well. The bushings sat in the freezer for a couple days, and were good and firm when it was time to drill. It was drilling just fine, but the problem became the fact that there's not enough meat there to drill it out to 27mm. The outside of the bushing is 29.5mm, so I was trying to drill a hole from 19mm to 27mm in material that had an overall diameter of 29.5mm. That only left 1.25mm of squishy rubber (polyurethane) around the drill bit. Simply not enough for this process.
Joe, I'll be in touch.
Old Dec 20, 2010 | 02:56 PM
welfarepc's Avatar
always busy jaques... haha i think you are more dedicated than i am!
oderfla90
Jun 19, 2015 06:38 PM
jdm4drSi
120
Sep 29, 2011 06:43 AM
EF_ST@TUS
Mar 22, 2008 09:36 PM
JDM Panda
Sep 11, 2005 02:55 PM
gpeele
Oct 1, 2004 07:19 AM
