Need help Plzzz!! hose questioins
Old Dec 3, 2010 | 04:27 PM
Ryan559's Avatar
Default Need help Plzzz!! hose questioins
im in the middle of doing a mpfi conversion and im not sure what these hoses go to plzzz help i need to get this car running.
does number one go to number 2?
also goes there in the back of the manifold
Old Dec 3, 2010 | 05:46 PM
Crx dude's Avatar
Default Re: Need help Plzzz!! hose questioins
For the first pic, thats for the Fast Idle Solenoid. #1 does hook up to #2.
Old Dec 3, 2010 | 06:28 PM
Ryan559's Avatar
alright thanks but now i got another problem i just got the car back together and started it up and well first i forgot to put the radiator cap on and anti freeze went everywhere....
but no i have gas shooting out of the top of the side of the injector where the fuel rail and the injector meet does this mean my injectors or bad or the seals??
Old Dec 3, 2010 | 07:34 PM
sobosscrx's Avatar
The injecters should be fine. You just need new seals for the injectors. Make sure to lube the seals before you put them in. Also make sure the fuel rail is flush with the injectors and manifold.
Old Dec 4, 2010 | 06:35 AM
Ryan559's Avatar
alright thanks ill try that
Old Dec 4, 2010 | 10:20 AM
Ryan559's Avatar
alright i fixed the leak but do u need the fast idle solenoid for the car to start? the car cranks but wont fire and when crank it it like backs fires for a sec . I have spark and fuel All my wiring is correct but im not sure about all the hoses i dont have a fast idle solenoid in the manifold at all so its just open would that cause it from starting?
oh and im throwing code 6 water temperature sensor and code 10 iat sensor i was thowing code 4 crank angle sensor but i think i switched the wires and it went away
Old Dec 4, 2010 | 11:23 AM
jlicrx's Avatar
the car doesn't need the FICV in order to start and run, but you need to block off the hole into the manifold - it is causing a huge vacuum leak
Old Dec 4, 2010 | 12:16 PM
Ryan559's Avatar
yea thats what i thinking but can find anything that will srew into it to fix the leak
levinz11
Aug 31, 2015 06:26 PM
jdm.coupe3234
Jan 5, 2010 09:40 PM
verizon521
Mar 12, 2007 09:21 PM
Ronin150
Jul 18, 2005 01:40 PM
DBallz
Mar 3, 2003 12:18 PM
