eg b16 radiator hoses
Old Dec 3, 2010 | 03:26 PM
jthrasher1's Avatar
Default eg b16 radiator hoses
i swapped a b16 into my eg coupe and the bottom hose lines up to ware its supose to go but will not fit over the fiting and the top hose is noware close to being right anyone know what hoses i need? any info thnx
Old Dec 3, 2010 | 03:38 PM
94EG8's Avatar
Seagull Management
Default Re: eg b16 radiator hoses
Del Sol VTEC, if using the stock civic rad you'll need some gear style adjustable hose clamps. If you happen to need a rad now is a great time to upgrade to a Del Sol VTEC rad with the larger B-series inlets.
Old Dec 4, 2010 | 07:05 AM
jthrasher1's Avatar
k so i went and got hoses for a del sol 1.6 dohc vtec and the top hose would work if it were long enough in order to reach the radiator it has to be pulled back like 3 inches and that wont work and the bottom hose is the same one i aready had still to thin so i dno what to do...
ForgetMyNameX07
Nov 7, 2008 06:29 AM
del sol1658
12
Nov 20, 2006 06:02 PM
looxs
13
Jun 2, 2006 02:27 PM
CRXified
10
Apr 26, 2005 06:54 PM
egciviccx
Mar 28, 2003 11:37 AM
