si cam in dpfi to mpfi, is this important
Old Dec 3, 2010 | 01:52 PM
Al_90HB's Avatar
Icon2 si cam in dpfi to mpfi, is this important
im doing a dpfi to mpfi swap here real soon and im wondering if adding the si cam will help my valves suck in more fuel and air. is it really worth the extra time to put it in or just wait to get a true performance cam. im shootin for more compression through one of these methods!
Old Dec 3, 2010 | 02:47 PM
alex14's Avatar
Default Re: si cam in dpfi to mpfi, is this important
I think it will help get a little more power but not much. I would just grind your cam or get an aftermarket one.
Old Dec 3, 2010 | 03:27 PM
Radim's Avatar
Yes it will give you more power over a B1/B2.
Up to you if you want to swap the cam or not.
Old Dec 3, 2010 | 05:45 PM
Al_90HB's Avatar
great thanks, i might as well it will only take a few extra mins to throw it in...... will i need to do a valve lash adjustment or not?!
Old Dec 3, 2010 | 05:54 PM
Crx dude's Avatar
valve lash specs are the same for both cams but it doesnt hurt to check and adjust anyways.
Old Dec 3, 2010 | 05:56 PM
Al_90HB's Avatar
figured that, just like it dont hurt to ask.
can anyone tell me the difference between the two cams...? i assume that the lobes may be slightly bigger which is why i wanted to put them in....
Old Dec 3, 2010 | 06:35 PM
Radim's Avatar
Yes.
Old Dec 3, 2010 | 07:14 PM
rudyndrew's Avatar
Heard other talks about this on this forum & they say that its the same as the b2 cam, so to just leave it alone.
Old Dec 3, 2010 | 10:23 PM
FSRslug's Avatar
The A6 cam is different than the B2 cam.
integra gsr96
Apr 13, 2008 05:12 PM
Sheep
29
Apr 2, 2007 11:01 PM
Screaming
Jan 30, 2006 08:59 PM
CPR
Jan 20, 2006 09:06 PM
GreenBean
Jun 3, 2005 12:20 PM
