d15b8 and d16a6 same internals?
Old Dec 2, 2010 | 11:01 PM
hatchet_honda's Avatar
Default d15b8 and d16a6 same internals?
im swapping a single cam back into my 91 si to pass emissions testing. i have the stock d16a6 apart and a bare 92 cx block. the a6 needs the block decked cause of the block mating surface is nasty as a ****. i was gonna put the a6 internals into the b8 block with new rings. should work aye?? i was curious cause the cx engine was the 8 valve and had diff pistons but im thinking the only diff is the valve recesses on top
Old Dec 3, 2010 | 11:16 AM
AutoShepherd's Avatar
Default Re: d15b8 and d16a6 same internals?
The internals are not the same, they are what make up the different displacements. The block however is similar. The bore is the same for both blocks. The only difference is the stroke. You can theoretically swap the entire internals and get the displacement for that internal setup. I don't know how the head is going to fit though. Again, theoretically, everything should fit together just fine.
Old Dec 3, 2010 | 04:49 PM
24TEN's Avatar
PHANTOM MENACE
^I don't believe that is correct. I believe the journal sizes are different not to mention deck heights are also different making it NOT a direct swap with respect to rotating assemblies (also not doable without some custom/major modification).
In it's most basic form, the B8 is just like a B2/7 as long as it uses the pistons meant for 16 valves. Having said that, you can swap your A6 head if you like.
NOTE: 88-91 blocks have the fan switch on the back of the block, 92+ have it on the thermostat housing.
Old Dec 4, 2010 | 08:20 AM
yea im thinking i may just take the a6 block to be decked. also i found another a6 complete on craigslist for 150. i may just pick that up. whatevers cheaper and easier. all i want is to get legal plates on this car. i really hate lake county indiana
eg:R
Apr 19, 2014 08:56 AM
carbon fiber coupe
Sep 26, 2011 01:56 PM
90LSpimpin
34
Aug 9, 2005 02:23 PM
