E-85??
Nothing that tuning again won't gain. it may be a few cents less at the pump, but you'll need an even larger injector as the BTUs are half of what 93 octane is. You'll be at the pump twice as often (as many have who decided to go this route), so your savings at the pump will be a moot point.
Honestly, I don't think its worth it. And we have it all around here. Especially NA. you can gain 10 hp in other ways
I think E85 is an ideal choice. At only 2.50 a gallon, that's alot of savings. C16 is 15-16 bucks a gallon?
My high compression 85x89 B series on E85 made 263 whp 163 tq running 750cc injectors
I'm not sure of any gains, because I ran e85 from the start.
On my gsr, I run itr pistons, 2layer head gasket and flat valves, netting me just under 12:1 compression.
Even with a blox cam rmf replica header and 60mm exhaust, all of which aren't the best for na horsepower, it put down 210 to the wheels on a dyno dynamics dyno on e85 with injector dynamics 1000s.
I'm very happy with the results, I've got maybe 4000 miles on the setup, and drive it hard. I change oil often though, and it doesn't seem to foul out plugs as quick.
Can you guys pitch in what fuel pumps/setups you guys running with e85. I heard that walbros arent e85 compatible.....that what i heard tough. Some one chime in. Ima be running a walbro 255 stock fuel lines, replace the oem filter with something e85 compatible to a aem fuel rail and id1000 cc on my 84.5x89 b20v at around 13.5CR.
Thanks
Thanks
Thanks
Thanks
To each his own. I used it for a while, and found little worth in it. But it depends upon what you want to do with the car.
Read my point on the BTUs. $2.50/gallond doesn't mean much if you're at the pump at least 2 times a week instead of once. And I compared that to 93-94octane, not C16. C16 would only be used on a setup made strictly for racing.
Thanks
