Cam selection
b18c with pr3 head
compression between 13.2-13.5:1
ported head
victor-x ported manifold
72mm throttle body
tri-y big tube header from rage performance
3" exhaust
which cam?
skunk2 pro1 pro2 pro3 ? or a different brand?
after i get a few repsonses i will tell you what skunk2 told me
ported head
72mm throttle body
3" exhaust
which cam?
81x87.2 or 1797cc hehe
skunk2 told me i was borderline on needing the pro3 and that either the pro2 or pro3 would work great in my motor....im still kinda in shock about needing a cam that large.
no one recommends rocket, bisi, endyn, or anyone else?
I thought of the Rocket M22x's as a possibility, they would be a bit more on the conservative side. The M22xx's would also compliment that motor well with the compression your running but be a bit more aggressive
How about possibly going with a custom grind? There really arent alot of new cams besides the bisi. But than again his product usually has alot of voodoo surrounding it and lil third party testing so dont know if ur the gambling type.
I vote my custom cams..
Cam Int. Duration Int. Lift Exh. Duration Exh. Lift
M24XX 298 12.7 305 12.1
I'm almost done in the making a street king cam.. i'll be testing vs the pro2's.. but thats later to come. If you want a custom grind, lemme know i can make you anything.
If it were me personally I'd go with Pro2s but, somewhat contradictingly, would recommend going Pro3s to you.
I had JUN IIIs with a similiar build many years ago, minus the port jobs. I defintely recall being in the 13.5:1 range with the same displacement. Correct me if I'm wrong but I heard the Pro2s lifts were almost, if not perfectly, identical to what the JUN IIIs lobes measured.
If that's even relatively true, although the Pro2's will be a beast in itself, I always felt a built head (I only had crower retainers/springs) with bigger cams could've been benificial. How much in comparison? Can't say. But what I can say is that the JUN IIIs/Skunk Pro2s will make you wonder at 9000rpm what it would be like had you chose the Pro3s. Good luck mate.
i feel like the motor is in that grey area and i should have gone 2liter
the crank and rods are stock gsr but they have both been worked pretty well...cryogen, magnaflux, etc
the bottom end is all ARP rods, mains, etc
the whole rotating assembly was balanced....this motor was originally built as an endurance motor to do scca/time attack etc...never intended to drag race it.
The M22's both have the exact same VTEC lobes, the xx versions have larger primary lobes making them more "pro series like". I think the M22xx cams would work awesome, the pro 2's would probably make slightly more power in the top end. I personally wouldn't go pro 3's in that motor unless it was at least a 2L. M24x's might be good but I never saw enough people that run them, post results.
For my car the M22xx cams are probably "best" for me. I learned that through swapping out my M22x cams for pro 2's that are in there now, I've looked at builds similar to mine and yours that ran pro 2's on the dyno and that's what I would choose to run if I were you.
Purchase the pro 2's and see if you can "borrow" a set of Pro 3's so that way you know which cam truly works the best. I have a feeling your gonna buy the 2's and still wonder if the 3's would have made more lol
i will be dreaming of pro3 cams if i buy the pro2.
Just remember the PURPOSE of your car man. not just power, but actual use. I thought the same thing in my build, and wound up going DOWN the chain to get the powerband I was looking for. Don't let your vision of purpose get impeded by stupid dyno numbers. look at what you're trying to do with this thing...
You may dream of Pro3s, but then you'll wake up and be happy that were a little less aggressive and had more usable power in the morning.
