follow the arrows
Old Dec 2, 2010 | 03:11 PM
sh!ft's Avatar
Who the fack changed my title?!
Default follow the arrows
and tell me what the hellgoes here/there. besides the knock sensor
and also these. and as well i have a question about how wide you can drill a motor mount hole.
Old Dec 2, 2010 | 04:14 PM
megomaniac's Avatar
Default Re: follow the arrows
2700+ posts and you don't know how to look for a service manual?
Old Dec 2, 2010 | 04:22 PM
sh!ft's Avatar
1 post and you cant just answer the question correctly?
you got 2,699 other reasons to explain your stupidity.
Old Dec 2, 2010 | 04:58 PM
2point1's Avatar
First pic two to the right are for the black box aka breather and the 2nd pic the one to the left is for the timing belt tensioner and spring and the bottom right pic is for the oil pump..
Old Dec 2, 2010 | 05:04 PM
94EG8's Avatar
Seagull Management
Old Dec 2, 2010 | 05:16 PM
sh!ft's Avatar
are you sure? i thought that was for the knock sensor where the nipple goes
Old Dec 2, 2010 | 05:36 PM
2point1's Avatar
Uploaded with ImageShack.us
Old Dec 2, 2010 | 05:37 PM
wishingiam's Avatar
Originally Posted by 94EG8
From top to bottom.
Top nipple goes to pcv (corrected) thanks for the pic 2point1
threaded fitting is knock, and smooth hole in block is for pcv.
2nd pic is correct. Last hole on the right is for the oil pump.
Old Dec 2, 2010 | 05:48 PM
2point1's Avatar
Old Dec 2, 2010 | 06:06 PM
sh!ft's Avatar
the one next to that is that the temp switch for the coolant? or wait, thats the one on the thermo housing.
ps- am jellous. u have an oil cooler. i want one!
Old Dec 2, 2010 | 06:22 PM
2point1's Avatar
The one on the thermostat housing is the fan switch..the one on the back of the block I'm not sure what it is used for but is not needed Honda even got rid of it
dawrenn
Jun 5, 2005 08:27 AM
wsiracerz
Feb 19, 2004 07:16 PM
ramdog
Oct 26, 2002 02:25 PM
boosted spoon
Sep 3, 2002 05:11 PM
