Signaling Issue when Braking
Old Dec 2, 2010 | 01:40 PM
end005's Avatar
Default Signaling Issue when Braking
Basically, when I step on the brakes and signal left, the green (left) arrow become dimly lit and the signal doesn't work. WHen I release the brakes, the signaling works like normal. This occurs only when I signal left.
Help??
Old Dec 3, 2010 | 02:39 PM
AutoShepherd's Avatar
Default Re: Signaling Issue when Braking
That's sounds like its going to be caused by unwanted high resistance. Check for loose or corroded ground wires, or connectors.
Is the problem intermittent?
Old Dec 5, 2010 | 06:43 PM
ef4real's Avatar
x2 loose ground wires, or other burned out bulbs. check and recheck.
Old Dec 6, 2010 | 05:56 AM
end005's Avatar
Imma knock on some wood, but its not happening anymore. Wierd.
Ghuy
Apr 24, 2008 07:46 AM
tron-R
Jul 25, 2007 08:36 AM
druciferrr
Jul 8, 2007 12:50 PM
mr 636
Apr 6, 2006 07:26 PM
crxtreme27
Jun 10, 2003 10:03 PM
