need help with swap!!
Old Dec 2, 2010 | 09:56 AM
carter77's Avatar
Icon2 need help with swap!!
well my ? is i have a built d15b2 block with z6 head w/blox intake mani..built for boost. what car would be best to throw this swap in? without having to do alot of wirring any help would be great thanks.
Old Dec 2, 2010 | 10:15 AM
alex14's Avatar
Default Re: need help with swap!!
EG body would be best because its already OBD1 and MPFI. If you want to use an EF I would find a SI hatch or SI CRX because its already MPFI. If you use a LX/Dx chassis you will need to re-wire some things.
Old Dec 2, 2010 | 10:49 AM
jdmhonda23's Avatar
CRX would be the easiest. good luck
Old Dec 2, 2010 | 11:57 AM
carter77's Avatar
ok i can get a cheap crx si shell what engine harness would be best,dizzy,and what ecu do i need!! iv got a evo resistor box nd the injectors already as well how would i run them?? if the engine harness you require will need some cutting and splicing id rather pay someone to do it and have it done. im a dummy when it comes to wirring.
Old Dec 2, 2010 | 12:56 PM
carter77's Avatar
pleaseee help want to get this car on the road soon!!
Old Dec 2, 2010 | 01:04 PM
FSRslug's Avatar
No matter what you do there is going to be wiring work that is needed. You have a Z6 head, you should use a Z6 dizzy. Use a P28 ECU.
Old Dec 2, 2010 | 01:18 PM
carter77's Avatar
ok so can i use a z6 engine harness? the crx is obd0 so what all plugs will need to be switched over? the ones on the shock tower? if so is there a wire color coating to change them over ill need the write up?
Old Dec 2, 2010 | 01:23 PM
HondaPartsHero's Avatar
Technical Hero
Don't forget the ALMIGHTY HF CRX, ha, its already MPFI as well and a lighter car all over
Old Dec 2, 2010 | 01:49 PM
FSRslug's Avatar
No offense, but it sounds like you shouldn't be doing this project. If you are going to pay someone else to do it, ask them what is easiest for them to work with and then get those parts.
You can use the Z6 engine harness, but it probably is more work than if you just used an OBD-0 MPFI harness. Then you just need to swap the Dizzy plugs, the Vtec plugs, and maybe injectors(I don't know anything about evo injectors)
If you use the Z6 harness your plugs will match, but you will need to swap the shock tower plugs which will be a pain to cut, strip, solder, and heat shrink that many wires in a small space.
What are you expecting the swap to cost?
Old Dec 2, 2010 | 03:52 PM
carter77's Avatar
not sure how much? i just picked up a z6 dizzy and p28 for 100 bucks even now i have to do the wiring..and its shuld fire up and be done..beside the tune also would chrome be fine? for a tune
turbocrx518
Mar 4, 2011 08:08 AM
CRXguy_88
11
Mar 1, 2010 03:47 AM
Sipocketrocket
Nov 7, 2009 05:49 PM
puertoricanboy90
Feb 1, 2009 09:10 PM
