99 Civic HX with EGR CEL code
Old Dec 1, 2010 | 11:40 PM
99civichx's Avatar
Default 99 Civic HX with EGR CEL code
ok, 99 civic hx basically its just one code and it says egr valve faulty well a few days b4 that code came up my car was runnin fine and didnt skip a beat.. since the code came up, welll not the same story... its still good til i hit bout 6500rpms.. once i hit those rpms it will sputter... i went to auto zone and they said clean the egr valve and where it sits as well.... will that be the fix? or what???? thanks....
Old Dec 2, 2010 | 12:35 AM
99civichx's Avatar
Default Re: CEL trouble
its either that or i just take the egr valve off..... where i live i dont have emissions
Old Dec 2, 2010 | 01:54 AM
Solster's Avatar
Emissions or not if your driving a "stock" car (ie No engine Mods) then removing it is a violation of federal law. (like i could give a S**T)
in my state i can drive with out a cator any other emissions crap as long as the car can no classed as Custom or Modified
so for this i have to have motor work and body work that is NOT stock done to the car.
any way the answer is NO you car is OBDII and it has to have the EGR valve to run correctly.
the best thing i can tell you is use carb and chock cleaner and clean it all up put it back on and get the code cleared.
the reason the car runs funny is what the computer does once the Cel is on is it runs on limited sensors and adds more fuel then is needed
Old Dec 2, 2010 | 03:52 AM
Former User's Avatar
This is a common problem of the Civic HX. Clean the EGR valve and the port and passage ways inside the EGR chamber.
Old Dec 2, 2010 | 05:19 AM
deadazleep's Avatar
Default Re: 99 Civic HX with EGR CEL code
my freinds 2000 hx had the same issue, cleaned the valve only and the CEL went off just long enough to get inspected but came back on, guess i'll be doing the chamber next and she claimed to get better mpg's since the valve was cleaned, glad to see this is a common easy fix
Old Dec 2, 2010 | 09:59 AM
99civichx's Avatar
alright cool... ill prolly get some carb cleaner and do that soon
Old Dec 2, 2010 | 10:03 AM
99civichx's Avatar
hell might as well get it done b4 the turbo goes on..... i dont need the motor to b;ow just cause of some carbon build up lol
Electron_Blue_Kid
Mar 24, 2009 04:23 PM
typeSH714
Apr 11, 2006 12:54 PM
brianr67
Jun 2, 2005 04:26 AM
