91 hatch w/ls swap oil leak ques
Old Dec 1, 2010 | 06:42 PM
spoon93's Avatar
Default 91 hatch w/ls swap oil leak ques
Ok I have a 91 hatch with a ls turbo I jus got home after taken it out for a spin looked under the hood and there's oil all over on the top of the tranny any ideas where this came from could it be the head lifting I did a comp test and it was 140 across the board any ideas also oil is fine and coolant no signs car also runs fine
Old Dec 1, 2010 | 07:56 PM
FSRslug's Avatar
Default Re: 91 hatch w/ls swap oil leak ques
Distributor o-ring.
Old Dec 2, 2010 | 09:23 AM
spoon93's Avatar
That's wat I'm thinken I also noticed only 2 bolts on the dizzy so I put the 3rd bottom one on well see
Old Dec 2, 2010 | 09:33 AM
.Manny.'s Avatar
Touching My Member
Clean the engine. the leak will be easy to spot when you have a clean slate to work with
Old Dec 2, 2010 | 09:49 AM
FSRslug's Avatar
+1
Also could be valve cover gasket. The VC gasket and Dizzy o-ring are more likely than a head gasket, but a clean engine is easier to work on than a dirty one.
Old Dec 2, 2010 | 10:56 AM
spoon93's Avatar
Ya the whole engine bay was clean as he'll until this little incident lol so I'm gonna clean all that **** and see wat happens thanks guys
Old Dec 5, 2010 | 03:05 PM
djstevehawken's Avatar
Same thing happened to me when I bought a new dist. off ebay. I replaced the O-ring with a OEM one and its been dry since.
92_luder
14
Mar 2, 2012 10:51 AM
curtie94
Jul 9, 2011 09:16 PM
ryanevansoh
11
Mar 15, 2010 01:53 PM
sshiny007
Jan 4, 2010 05:35 PM
CEB76
Apr 30, 2004 08:03 AM
