best internal B16A2 OEM rebuild??
i got a b16a2 engine block that i'm rebuilding for a nice daily..should i just go OEM b16a2 internals again or what would be a nice set up for a nice power n compression? thanks
Get P30 pistons if your looking at OEM parts. Locate some ITR/CTR cams, a good header, IM and exhaust, get it tuned and you should be happy. What kind of budget and power are you going for?
also all of the high compression n/a motors running on alcohol/methanol/ethanol/q16/c16 have pistons with rather large domes
to the OP
i would switch to PCT pistons in that b16 along with throwing in some ctr cams/springs/retainers
if the PCT piston was good enough for the b16b from honda its good enough for you
if you understood how flame propagation works in the cylinder then you would understand that statement is false. dont get why people bash ctr pistons. me and plenty of other people have made a lot of power n/a with them
also all of the high compression n/a motors running on alcohol/methanol/ethanol have pistons with rather large domes
Im not trying to create an arguement, just my experience with the CTR pistons have never been top grade. MOST motors I have seen torn down running them the pistons were caked in unburned crap and such. In a B16 they do work pretty well as apposed to a 1.8, put I still like the P30's or a custom dome over them.
I know/you seem like your a reputable tuner so I dont second guess what you say. I know we had a headbutting clash about the supertech VS, but thats just an opinion thing. No hard feelings from me.
I don't know but my friend had PCTs .10 oversized(81.25) in his b16a/b16a2 head 97 h/b, crappy i/h/e with a CTR tranny and we through in my CTR cams and guess what, **** pulled pretty hard untuned. Imagine if it was dyno tuned with proper bolt-ons. Everything else was stock.
There is quite a defference in the PR3 and P30 pistons. PR3's have a small dome, flat of the top. P30's have a larger dome thats a bit more "peaked" The compression difference if he were to bore the motor and run them would get him in the 10.5:1-ish range. The PR3's will be at 10.2:1
pr3 pistons put you around 10.2:1 c/r
p30 pistons puts you around 10.4:1 c/r
PCT pistons put you around 11.9:1 c/r
going from pr3 to p30 pistons is useless...that whole 0.2 difference in compression will do nothing....going from 10.2-10.4:1 to 11.9:1 however will give you a bump in power. plus later on down the road if you decide to go to a bigger cam you will at least have the compression to run it. all i see is win win with the b16b pistons here.
A GSR or LS crank will never go in a B16A, EVER. The static CR of a B16 w/ a LS crank is sometthing like 35:1. You would need to have some sort of SHORT and I mean SHORT rods produced.
1.8 cranks go with B18's and the B16B
1.6 cranks go with B16A's.
This would be about like running a B16A crank in a LS or B20, about as useful as a poopy flavored lollypop
Call me out on a typo, cool.
I forgot the deck height is shorter on the b16a, I would still find a crank/rod setup with a longer stroke, or just go with a bigger block.
Or he could just go with what you said and get a miniscule diffrence in cr by switching his pistons, what do I know im just a retart right?
type r cams
type r valvetrain, or aftermarket upgrade
tune.
Man_EK9
Feb 10, 2008 11:52 AM
