Fuel pressure Help wanted !!
Old Dec 1, 2010 | 12:01 PM
attack666's Avatar
Default Fuel pressure Help wanted !!
Guys, i just finished my turbo civic fuel system. and i cant lower the pressure from 70PSI. this is what the fuel rail gauge reads, it idles at 70PSI and when i give it some rpm it drops to 50ish PSI.
my mechanic did what ever he could with the aem regulator and pressure is still the same, swaped it with the stock b16 regulator again same, even swapped the fuel rails. swapped my 1000cc injectors to 650cc and still the same. i Cant seem to find how to lower the pressure.
Fuel setup:
External walbro 255 fuel pump
-6 line
High flow fuel filter
golden eagle fuel rail
AEM fuel pressure regulator
Summit Fuel rail gauge
650/1000cc injectors
Old Dec 1, 2010 | 02:04 PM
lsvtecracer's Avatar
Default Re: Fuel pressure Help wanted !!
Is the fuel gauge good and working correctly?? Could be a partially block fuel return line.
Steve
Old Dec 1, 2010 | 10:39 PM
attack666's Avatar
[QUOTE=lsvtecracer;44131585]Is the fuel gauge good and working correctly?? Could be a partially block fuel return line.
Steve[/QUOTE
Well the gauge is brand new just installed it..could be bad?
I am going to do another new return line but the one I made now is new.but I'll double check on this one.
Any more input would be appreciated guys]
Old Dec 1, 2010 | 10:46 PM
HAMOTORSPORTS's Avatar
Are you checking fuel pressure with the vacuum line connected or disconnected/plugged??
Old Dec 2, 2010 | 09:45 AM
turbodcxbro's Avatar
Get another gauge...
Old Dec 3, 2010 | 02:46 AM
attack666's Avatar
rechecked the return line.. it was totally blocked !!
finally my fuel system is working right.
thanks for your help guys.
Old Dec 3, 2010 | 06:53 AM
Glad you fix it. Time to go make some power!
Steve
boostinscrappy
Honda S2000
Jun 30, 2013 06:05 PM
