Transmission & Drivetrain Gearboxes, Differentials, Clutches
DIY Short throw shifter/bearing conversion.
Old Dec 1, 2010 | 11:21 AM
cjw_89's Avatar
Default DIY Short throw shifter/bearing conversion.
So i decided to modify my integra dual bend shifter today.It starter with two throttle body bearings i got from a dodge stratus throttle body.I then got a piece of pipe about an inch in length for the bearings to press into.
Here is what i started with:
From there i cut the previous lower portion of the shifter off and and i extended it an inch.With the 1'' long pipe i welded a bolt to it and extended it where i was comfortable with.
I then filled the bolt in with weld and ground it down so it looks half sensible.
Heres a pick of the bearings pressed in like you would get with an aftermarket shifter.Why buy new when with some time make your own for nothing
I installled it after i finished.What a difference from upgrading to bearings over a bushing/rubber o-ring style.The shifts are just right too.Anyways i hope somebody gets this idea and uses it for thier shfter in the future. Cheers :thumb:
cmross13
Jan 25, 2010 07:05 PM
rutherfordhigh
Oct 27, 2008 10:42 AM
slammed95dc2
May 8, 2007 09:08 AM
Extreez
Dec 8, 2006 06:08 AM
BSERIEuS
Aug 25, 2005 09:07 AM
