what cams are you guys using ? ??vs oem
trying to get some input on what would be the best cam setup for me . my motorset is pretty much like everyone eleses in the honda world but for ***** and giggles ill list it ..
gsr head - crower ,springs ,retainers , oversized valves , oem jdm itr cams h22 lca
oem obd1 ignition , id 1000 , skunk2 composite fuel rail , victor x manifold ,omni 68mm tb 4 bar map
itr block - ge 84mm cp pistons 9-7-1 , manley turbo tuff rods ,gsr crank ,moroso oil pan
t1 catch can ,
full race - gt35 r , ram horn , 3 in down pipe , open dump tube , 3 in thermal exhaust,
my goals is to keep it streetable to drive to the track and drive it on the weeknds with a decent idle
thankyou for any info .
t1 catch can ,
if your goal is to keep it streetable to drive to the track and drive it on the weeknds with a decent idle then what are you looking for in a cam that the type Rs don't provide?
More info on these webcams? I've heard of them, just seems like all the 700+whp guys are using them.
On a turbo/street setup, get an AEM fuel rail, that's where the power is made!
But seriously.. (IMO), you don't need cams on a turbo/street setup unless your 650+ it just seems like a colossal waste of time, money, and effort. I'm no cam expert but I'm willing to bet that VTEC is already aggressive for an FI application; and that's probably one of the major reasons VTEC motors make great HP/L on FI as compared to other motors with the same displacement.
bahhh! <back to bed>
if ya want power, go with pro1s. or something similar.
the question is, what are your power goals?
you won't have idle issues with the pro1s. and you should get a hefty hp gain.
but like i said, depends on your hp goals. how efficient is your setup?
backdoor intercooler? charge pipe sizing? looks like the rest of your **** is up to par (besides not having a ported head) so cams should open it up quite a bit.
There are a lot of fast cars with aftermarket cams. If you don't have the right cam for the application and it doesn't work well then it's not the cams fault.
