spark plugs
Hey guys I was wondering what plugs you All Motor guys are running or recommend. I have a 01 GSR.B18c1 stock bottom end 70k on it. Ported & polished head, Skunk2 Valvetrain including +1 flat faced valves, stage2 cams & cam gears, springs, titanium retainers, Toda Tbelt, oem Type R intake and Tbody, short ram intake, Walboro 255 fp, 450 injectors, aem rail, RMF Narrow Header, 3" exhaust, Exedy stage2 clutch, Fidenza flywheel, p28 ecu tuned on crome. I think thats it. Anyways, what plugs would be best with My setup?? Bottom end gets built next!!
NGK V-Power plugs. Most reliable plugs I've ever used and I was using Iridium IX's until a gentleman who builds 400hp Beamers told me his luck with the VP's. I'll stick with these until they prove me wrong
i was using platinum. don't think theres much of an overall performance advantage besides not having to change them as much.
but use copper ngk plugs. which i think the VP's are. may have to change em every 30kish but they're good and cheap.
NGK Copper vpower plugs.. is the only thing you should be running..
this isn't k series. and its been very well prove that these plugs last and last..
Use the stock heat range (6) for your car..no need to upgrade..stock gap will also do just fine.
i run these http://www.inlinefour.com/spoonirracsp1.html in my built n/a motor and denso iridums in my daily driver.
they are made by denso for spoon to spoon spec....and i dont pay anywhere near that for them
they are also by far the best sparkplug I have ever used in my built motor.
how can a plug be any better than others if it fires right, the ground strap is the color it's supposed to be, and timing marks are in the correct spot?
I ran iridiums and those things would not fire correctly and it felt like i was always missing, switched to v-powers of the same heatrange just like everyone else runs and the car runs like a dream..
HybridGSR1
Oct 5, 2002 08:45 PM
