Problems after swap
Old Nov 30, 2010 | 02:53 PM
Shwilson's Avatar
Default Problems after swap
Ok so i blew the motor in my 02 accord. now i had a F23a4 ULEV and swapped it with the F23a1 now the problem is it runs great but it wont go over 4000rpm the limiter kicks in and thats it. Any suggestions?
Old Nov 30, 2010 | 03:29 PM
GhostAccord's Avatar
Default Re: Problems after swap
1. Does the check engine light come on?
If it does you should have the OBD system scanned for trouble codes. That would be the best place to start.
2. What ECU are you using? Are you using the stock ULEV ECU & O2 Sensors that came with the car?
ef8-dc2619
Jan 31, 2007 04:29 PM
superpirate25
Apr 5, 2005 04:37 PM
PhatwhipsJDMkits
Nov 28, 2004 03:46 PM
PhatwhipsJDMkits
Nov 28, 2004 09:31 AM
LilManSi
Jan 29, 2004 02:41 PM
