spoon calipers on EG
prolly coulda put this in the Brakes forum but was afraid no one would look at it lol. ok so iv done alot of research and just wana make sure i have my info right.
i wana put Spoon calipers on my EG. (95 EG coupe EX non abs)
So im going to need DC knuckles so the caliper will bolt on. (DC bearings)
ITR/Legend bracket and machine 3mm off because 5 lug hubs stick out farther than 4 lug.
prelude vtec rotors re-drilled to 4x100 (or aftermarket rotors. someone said fastbrakes makes them)
and ITR sized pads
done?
research done here...
http://www.team-integra.net/forum/di...agePosition=14
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/eg-civic-knuckle-same-dc2-itr-1710024/
and ITR sized pads
done?
A garage, removable steering wheel w/ locking hub, a python and a pitbull. My buddy had a set and within 10 days of install he had strange cars driving by him house at night...then a month later JACKED.
Lol thanks for the bumps and good advice. It is duely noted. But if I get them as a gift... I can't not use them.... Lol
So bump
Anyone know if my information is correct or not?
So bump
The EX has the same knuckle as a DC so you don't need to buy new knuckles.
All you need:
Spoon calipers
97-01 ITR-sized pads
92-96 Prelude VTEC-sized rotors drilled for 4x100
There are no ITR/Legend brackets to mill because the Spoon caliper is a self-contained unit. You can mill the Spoon calipers, mill your knuckle, or add a 3mm spacer behind the rotor. Consider that an optional part if you're unable to come to another solution.
Here's a thread that may have helped more than those two you posted:
https://honda-tech.com/forums/showthread.php
All you need:
Spoon calipers
smash fascism
Nov 21, 2004 06:13 AM
