Who can verify this is a GSR Harness?
Old Nov 29, 2010 | 05:00 PM
kevinoneill's Avatar
Default Who can verify this is a GSR Harness?
Could someone please verify this harness is a 94-95 GSR Harness? If you could just let me know what makes you sure. Thanks!
I know it may be a little difficult from photo's. I have a situation and if I can know for sure one way or the other that would help alot.
Thank you.
Old Nov 29, 2010 | 05:36 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Who can verify this is a GSR Harness?
There should be a round two wire plug where the top wire is Pink/Blue stripe and the bottom wire is Yellow/Black stripe this is for the IAB's on the GSR harness. It looks like it has it in the second pic, center round plug. On the same "strand" if that other wire connector to the right has one wire it is for the knock sensor.
Old Nov 29, 2010 | 06:09 PM
HAMOTORSPORTS's Avatar
Looks like it.. I see its b series cuz where the O2 plug is, has VTEC, and it looks like the IAB plug just below the green plug near injector harness, has OBD1 style alternator plug....
Old Nov 29, 2010 | 08:12 PM
1 Thing that was throwing me off, I did not see any plugs, towards where the o2 should be, that had 4 wires..., which I assumed would be needed for the 4 wire o2 sensor. I could be wrong on that account, it may have just 2 wires?
Old Nov 29, 2010 | 09:17 PM
Old Nov 30, 2010 | 09:34 AM
Thank you, this is helping.
I had searched all over google trying to find a labeled picture of a GSR harness.
Anyone know of one somewhere?
Old Nov 30, 2010 | 12:38 PM
Technical Hero
I took a shot in the dark using all 3 of your pictures as reference and made this:
plus rywire's diagrams below:
Old Nov 30, 2010 | 01:21 PM
Holy **** that is amazing (saved).
Wow wasn't expecting that, YOU ARE THE MAN!!!
I'd seen 1 of those rywire picts before, but i didn't find the rest of them!
See the bottom left, the 3 shock tower plugs, see how the very bottom one has a plug in it? Am I suppose to leave that plugged? My EG chassis harness only has 2 plugs...
Old Nov 30, 2010 | 01:27 PM
AllMoToRB18c's Avatar
Yes leave that plug the way it is
Old Nov 30, 2010 | 01:50 PM
Technical Hero
Yeah I was looking for that plug in the manual and couldn't find much info about it other than the wires in it run to the fuse box somehow, so it could be something on the integra underdash related?
Old Nov 30, 2010 | 06:51 PM
They are all the same color wire too, yellow/black if I remember right. I thought it was to go to a resistor box or something along the lines of a heat dissipator as I call them.
So we're all pretty sure we're looking at a GSR Harness then by the sounds of it.
Old Dec 1, 2010 | 07:48 AM
Technical Hero
Yeah look at that one I labeled IAB and see if the top wire is pink/blue and the bottom wire is yellow/black
Old Dec 13, 2010 | 07:37 PM
In that labeled photo, there are 2 wires labeled for the starter. I re-labled everything on the harness, and there is 1 additional plug I don't know what it is, which I pressume is the 2nd labeled starter wire.
My starter only has a spot for the wire I labeled, do we know what the other "????" wire is for?
Old Dec 14, 2010 | 04:26 AM
kyden's Avatar
how many wires is it? could be back up switch or vss.
Old Dec 14, 2010 | 05:32 AM
Its not in front of me unfortunately to look at
The VSS is accounted for, what do you mean by a backup?
Old Dec 14, 2010 | 05:56 AM
kyden's Avatar
reverse light switch
Old Dec 14, 2010 | 05:58 AM
oh haha, whoops.
That could be very possible actually, that's not accounted for.
Old Dec 19, 2010 | 12:20 PM
IT IS!! HURRAY BEER!
CunninLynguist
Jun 5, 2007 05:49 PM
VTcivicHB
Nov 8, 2005 03:44 PM
West Werks
Mar 10, 2005 08:10 AM
JerKeK9
Jan 19, 2005 09:16 PM
