I have a question for people with Type-One catback
Old Sep 22, 2002 | 01:18 PM
jdmspoonitr's Avatar
Default I have a question for people with Type-One catback
What gasket are you using to connect from the b-pipe to rear section??? The one I got from the muffler shop seems to be too thick and is making my exhaust hit the a-arm on bumps. Is there an OEM I should be using, and if there is, what is the part number or at least can you provide a pic???thanks
Old Sep 22, 2002 | 01:21 PM
DarthLuder's Avatar
New User
Default Re: I have a question for people with Type-One catback (jdmspoonitr)
huh?? only gasket i got was the one from cat to bpipe.
Old Sep 22, 2002 | 01:31 PM
Default Re: I have a question for people with Type-One catback (ITR GURU)
I know. From A&J I got absolutely no gasket to fit on b-pipe to rear section, which is why i went to a local muffler shop and they gave me a metal donut gasket, but I don't think it is the correct one. what are you using?
Old Sep 22, 2002 | 01:59 PM
B2FiNiTY's Avatar
The donut gasket I used was the stock b-pipe one. Fits perfect.
Old Sep 22, 2002 | 02:31 PM
DarthLuder's Avatar
New User
you got mail.(pic) Just found the gaskets. It came with two gaskets.
Old Sep 22, 2002 | 03:24 PM
CPR's Avatar
CPR
It came with 2 flat gaskets. One has 3 holes and is triangular in shape. This 3-holed gasket goes between the cat and b-pipe. The other gasket has 2 holes and it goes between the 2 pieces of the Type1 b-pipe. You will need a donut gasket to go between the b-pipe and muffler. This donut gasket is the exact same as the one that goes between the stock b-pipe and stock muffler.
[Modified by CPR, 7:28 PM 9/22/2002]
Old Sep 22, 2002 | 03:31 PM
Default Re: I have a question for people with Type-One catback (CPR)
anyone got the part number for the oem donut gasket??? My friend at the Honda dealership needs the part number to get it for me. Thanks in Advance
WaryDriver
Aug 16, 2013 07:26 AM
E JAY 1
Apr 4, 2008 09:31 AM
DevLishPlaya
Dec 9, 2003 11:06 AM
jdmspoonitr
Jul 3, 2002 04:27 AM
SamC
Apr 25, 2002 10:09 AM
