Honda CR-V & Element 2WD & 4WD Element & CR-V
2002 Honda CRV RT-AWD Front Brake Upgrade RSX Type S
Old Nov 28, 2010 | 02:06 AM
norcalem2's Avatar
Default 2002 Honda CRV RT-AWD Front Brake Upgrade RSX Type S
I am wondering if there is anyone else out there that has upgraded their brakes to a bigger rotor or bigger caliper? I have a set of RSX Type S calipers laying around and I was wondering if this is possible? I am 90% sure that this will work. I just don't want to spend the money if someone else has ran into an issue doing this swap.
I am thinking the parts I need are.
RSX Type S Calipers
RSX Type S Caliper Brackets
RSX Type S Rotor & Pads
16" inch rims or larger
Do you think I am missing anything?
OEM
2002-2004 Came with 11.1 Inch rotors
2005-2006 Came with 11.8 Inch rotors
Thats another reason why 2005-2006 came with 16" rims due to the bigger front rotor.
Old Nov 29, 2010 | 08:42 PM
luciferi's Avatar
Default Re: 2002 Honda CRV RT-AWD Front Brake Upgrade RSX Type S
All you need is the rsx-s/05-06 crv caliper bracket and rotor to convert from 11.1" to 11.8". The crv calipers are the same from 02-06 are the same, only the bracket is different. The rsx caliper uses the same size piston as the crv.
Old Nov 29, 2010 | 11:39 PM
norcalem2's Avatar
Thank you for your help. I am going to try this in the spring. Its too cold out side to work on my car.
xiongtoua1990
Apr 12, 2009 11:02 PM
tougemax123
Suspension & Brakes
Mar 18, 2008 07:02 AM
187Chor
Nov 14, 2007 09:07 PM
