After z6 to y8 intake manifold swap, fuel rail cap does not match up
Old Nov 27, 2010 | 09:57 PM
Tyla12's Avatar
Default After z6 to y8 intake manifold swap, fuel rail cap does not match up
i was swapping intake manifolds from z6 to y8. and found out that the top fuel rail cap dosent match up,anyone know what will? will a b8 work?
thanks
Old Nov 27, 2010 | 10:13 PM
NotAJDMFanBoy's Avatar
Default Re: z6 to y8 intake mani fuel rail probleme
you probably need a 96-00 rail. I noticed this before. I was going to just drill a hole but there wasn't a spot to drill one of them...
Old Nov 28, 2010 | 06:13 AM
cvcrcr99's Avatar
I believe you do need a rail from a y8. They are not interchangeable.
Old Nov 28, 2010 | 07:37 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: After z6 to y8 intake manifold swap, fuel rail cap does not match up
The Y8 rail will be needed for the best results. But when I did the manifold swap back in the day I just drill holes in the rail (not the fuel filled portion obviously) that matched up with the Y8 manifold's and then used longer bolts to secure it.
Old Nov 28, 2010 | 01:45 PM
Tyla12's Avatar
dang hoping i wouldent have to do that,thanks
zach1288
Mar 27, 2010 03:16 PM
kmeng
Feb 26, 2009 12:42 PM
EGandDArida
Nov 12, 2008 08:18 AM
vegaskurt
Apr 22, 2005 02:26 PM
JCracer723
Jun 5, 2003 11:40 PM
