Oil in coolant
Old Nov 27, 2010 | 01:05 PM
nicknack25's Avatar
Default Oil in coolant
Sup guys i have a b18a1 and i recently changed my blown head gasket but i am still getting oil in my coolant reservoir. Found out i have a bad water pump and i seen coolant behind the motor on the shift linkage. Is the oil in the reservoir caused by the water pump or is it possible to have a cracked block?... Help please!
Old Nov 27, 2010 | 04:15 PM
1991civicsi's Avatar
Default Re: Oil in coolant
A cracked sleeve would mix the oil and coolant, but the headgasket is more likely. Did you check if the head is warped, or the block may need to be decked.
Old Nov 28, 2010 | 03:29 PM
nicknack25's Avatar
I dont think the head it warped. I resurfaced a b1 head when i changed my head gasket. I'll try doing a compression test soon.
Old Nov 28, 2010 | 04:52 PM
nicknack25's Avatar
Would this cause me not to pass a smog test? because my smog test is due feb.
ssmc12
Apr 8, 2012 01:19 PM
si-ej1
Nov 2, 2011 06:16 PM
david45249
Honda Civic (2001 - 2005)
20
May 24, 2011 04:13 PM
lakerschamp2000
Apr 20, 2009 10:51 AM
Halo
Aug 12, 2002 06:27 PM
