Do any of you guys use AEM cam gears?
Just wondering if its a good idea to purchase some cam gears and have a little something extra to tune my car on the dyno. Do any of you guys use them and does it make a considerable difference for turbo'd cars?
aem cam gears kinda are sketchy... they only have 3 bolts... they slipped on a friend of mines ls/vtec motor and bent a ton of valves... so try to stay away... go with skunk or any other .. that have liek 6 bolts and torque them dowN!
oh really that sux...aside from that does anyone else use camgears in general, for their setup?
[Modified by NHB Fighter, 4:13 PM 9/22/2002]
I had them for a few months and had one of the bolts begin to strip on me. After reading a few horror stories I decided that my VERY expensive built motor wasn't going to take a chance with them, so I got the Skunk2 gears instead. That's just me though.
-Trung
-Trung
i have an aem cam gear on my sohc, i'm missing one bolt so i really only have 2, had it for a year, hasn't slip on me, u can tell the difference when tunning, mines retarded right now getting ready for some nos.
i had a set on my car and threw one of the bolts off and let the gear slip. Got a new bolt and still run the same gears without a problem since.
I've got a set of AEM trutime camgears in my teg.. no problems so far.. and has helped extract lots of power from the B18C-R cams that i'm using too..
I now will only use HKS, Spoon, or JUN. They all use steel gears, just like OEM.
I've had aem gears on my car for 3 years now without too many problems. Mine had the older allen heat bolts and the heads on those ones WILL strip out, I replaced the bolts with some real bolts and washers and haven't ever had a problem. Their new gears come with regular bolts now instead of the crappy allen head ones.
I don't think one gear will show power increase over another. Just The steel ones have less of a tendancy to slip over the Aluminum.
The HKS sure are ugly though. I'd have to paint first.
i use the hks ones with great sucess just littl priced got them from tony at jotech when they built the car.
Are you sure your timing is the only thing thats retarded? 2 bolts is kinda asking for it!
Rob
