WHAT SHOULD I GO WITH!!? LS-VTEC, DUAL CAM ZC??
Old Nov 27, 2010 | 09:41 AM
HWKR3W's Avatar
Default WHAT SHOULD I GO WITH!!? LS-VTEC, DUAL CAM ZC??
hey whats uuuup evrybody. i got a quick question. i have a 88' ef hatch. i plan on putting a swap in it but i cant decide what to put in it. i want sum hp numbers on a couple of engines.
engines of interest:
+ ls-vtec (of out a dc integra with cams an bolt ons)
+ dual cam zc ( with cams an bolt ons)
+b18-vtec.
thats bout the only motors i want. how many horses? what wuld best benefit my hatch?? an why? an what trannys would i need!!? lol i know its alot of questions but i jus want to be sure. thanks for your help.
Old Nov 27, 2010 | 11:18 AM
efcivic317's Avatar
Default Re: WHAT SHOULD I GO WITH!!? LS-VTEC, DUAL CAM ZC??
LSVtec isnt out of a certain car, its a B18a or b18b block with a b16 head. Correct me if im wrong guys. B16 trannys have shorter gears then a b18 so id go with B16. i would go with a LS Vtec if you can afford it.
Old Nov 27, 2010 | 11:19 AM
Eran's Avatar
HT White Ops
Windsor 302 with a Whipple roots charger.
Old Nov 27, 2010 | 11:33 AM
HWKR3W's Avatar
oooo ok. ya but its going to be my daily driver. my friend has a b16 tranny is his eg an he said yaa htey hve the shorter gears but they also burn gas way faster. soo ya i may jus go with the b18 tranny. or would a gsr trans fit?
Old Nov 27, 2010 | 11:55 AM
THE GREEN CRX//'s Avatar
i heard the integra ones are better
at least the gear ratio is longer
which in my option is better
you have a higher top speed.
and less gas consumption,..
Old Nov 27, 2010 | 02:29 PM
HWKR3W's Avatar
ook. so i should go with the ls integra tranny?? out of a dc?
Old Nov 27, 2010 | 03:33 PM
mruneek's Avatar
are you guys serious about the difference on gas mileage between the b16 tranny and the ls... umm u got a honda, not " windsor " dont worry about gas miles. most y1 "cable b16 tranny" and have lsd and better final drive then any ls. unless moded
Redline130's Avatar
Unless you want to convert to a hydraulic transmission, you will want a cable transmission.
Old Nov 27, 2010 | 03:37 PM
Redline130's Avatar
Well, some people don't want to be driving down the highway at 75+ mph at over 3500 rpms...I know I didn't like it when I still drove my car on the road.
Old Nov 27, 2010 | 06:34 PM
HWKR3W's Avatar
lol yaa but trust me the gear ratioes make a huuge difference. exspeciaally when i drive as muuch as me!
Old Nov 27, 2010 | 08:07 PM
Grnnt4's Avatar
Is this really happening? Lol if u want gas mileage get a vx or hf d-series. Even with an SI tranny, you'll be good with at least some accelleration. Stick with the cable...
Or...u could get a b18c or ls/vtec motor with a tranny that's geared 1-4 b16, ls 5th for highway gearing. You'll need mounts, ecu, bla bla for that though...
Old Nov 27, 2010 | 10:46 PM
fndbt's Avatar
all this depends on what kind of budget you're looking for, and how much work you want to put in to the swap. is it your first? do you want to do wiring conversion work? vtec or not? no vtec now, but vtec later? to keep things as simple as possible, you'd want to stick with a cable tranny and any obd-0 motor. that is really the crucial part of your decision, i'd say. how much power are you looking for, now and later?
as far as the transmission question goes, i am about to try what grnnt4 above mentioned: over the winter: rebuild a b16 tranny but install the LS 5th gear. I do a fair bit of highway driving, so i want the LS 5th. here's what looks like a good writeup on this:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-how-ls-5th-gear-install-guide-jdm-b16-s1-555929/
i just did a 'repair swap' (my a6 was toast).. a quick and fairly easy swap was the b18a1. that tranny has long gears, but i kind of like them, which is why i'm keeping the 5th. it is definitely a torquey motor, but it's not a huge power gain.. i just no longer have to spin it to get power out of it, it's a much chiller drive.
Old Nov 28, 2010 | 06:08 AM
beansandrice's Avatar
this gudamn question pops up all the time.
Best answer; Open your wallet, whats inside?, base your swap off whats inside.
Old Nov 28, 2010 | 12:16 PM
LudeEFv2.4's Avatar
My old title sucked.
Don't do it kid, you'll shoot your eye out.
Old Nov 28, 2010 | 12:32 PM
jdm ef8 89's Avatar
I dont know why people overlook the jdm DOHC ZC its such a perfect fit for your crx/civic its obd0(possibly obd1) bolts right up to your tranny (hopefully si) and it has an underated 130+ hp (who needs vtec with that). Not to mention if you look you can find them for dirt cheap and the cost of puting it in your ef(ED) is next to nothing, so if your budget is in question it seems like the ZC is your best bet. But hey I guess im just a d-series lover do what ever will make your heart content.
Old Nov 28, 2010 | 12:41 PM
YG_Nicewicz's Avatar
the ls has more horse than the b16. but depending on wich ls you pick can make a difference as well. although the ls costs more. the real question is what are you plannign to do with them? make it all motor or drop in a turboo
Old Nov 28, 2010 | 12:42 PM
and as far as the tranny question go with the lsd tranny for power && gsr for daily driver
Jockone's Avatar
I agree with this 100%.Real easy swap good power cheap no mounts etc to buy.
I have done several of these swaps for people and no one has been disappointed.
Old Nov 28, 2010 | 03:29 PM
CRX Toad's Avatar
It is your car do what you want. Please do a search and decide which is best for you. We cannot answer this question as we see this similar question all the time. Thank You
jdm_jeners
18
Apr 24, 2007 06:44 AM
93LsVtecIntegra
Feb 15, 2007 06:58 PM
wicked2night
Aug 16, 2003 10:53 AM
EF7
Jan 28, 2003 08:35 PM
