T/W WTT 96 Integra
I've owned this car for about 8 months and it hasn't done me any wrong. Picked it up at 168xxx now sits at 183xxx. It's a 96 LS Special Edition Integra Doesn't, knock, tick, smoke or use any oil. Motor and trans fluid changed 2k ago. Royal Purple used in trans when I replaced the throw out bearing, pilot bearing, flywheel, clutch, rear pads/rotors and drive axle. Car likes to runs cold while driving. Barely gets over C sometimes, warms up when sitting but cools back down while driving. Car is in primer. One coat of primer surfacer called Pastacio green. Not jammed and the bay hasn't been done yet. Kinda just seeing whats out there. Only things I will trade for is another honda thats a 5 SPEED!!! Nothing else so please don't bother.
Still have most parts I've replaced. A-arms, mirrors, Antenna motor (works too), LCAs, etc
Since I must list a price it'll have to be 2500 obo but MAINLY LOOKING TO TRADE. CRX, Del Sol, EF, DA, EG, EK no Accords or Preludes
Exterior
Pastacio green
Antenna delete
broken driver handle
Some tasteful stickers
Replica Spoon Mirrors (Suck)
Interior
Tan (Converted to clothe)
Custom auto woodgrain shift plate
CTR shift boot
Custom wrapped armrest
350mm Broadway Mirror
EK tan Sun Visors
Motor
B18b1 LS with 183xxx no issues
S80 trans (no grinds)
10.2mm plug wires
NGK plugs
12lbs XTD Flywheel
Stage one XTD Clutch
New slave cylinder
Del Sol shifter (nice short shifts)
Poly shifter bushings
2.5' cat back with fart can (have a wild twin loop muffler to go along for right trade or price)
BWR Gold battery tie down
Gunmetal VMS with washer and bolt radiator stays
(Also have a set of Wiseco 10.5/1 pistons that can go with the car along with King main &
rod bearings & ARP rod bolts BNIP)
Suspension
Stock struts (coilovers in front RSR springs in rear)
Polished LCAs
Fully adjustable upper a arms
Rear camber kit
Shoes
14x6.5' BMW wheels (face painted white)
Audio
Jensens Stereo
Memphis Car Audio speakers
Has cruise, ps, pl, pw, All a/c components (took out when replaced flywheel and clutch)
CONS
Dash lights done work (trying to get that fixed)
Was backed into before I bought it but I fixed it the best I could
Driver headlight only has 2 good tabs
Exhaust leak from down pipe
Broken driver handle
Needs alignment to straighten steering wheel
I'm the 3rd owner of this car was always owned here in Springfield and have all service records ever done before me.
I'm sure theres more I'll remember later. PLEASE NO NEGATIVITY Don't like my car or price don't post. THANKS
Will get more better pix tomorrow after I wash it up and clean it out
Exterior
Pastacio green
Antenna delete
Interior
CTR shift boot
EK tan Sun Visors
Motor
10.2mm plug wires
NGK plugs
12lbs XTD Flywheel
New slave cylinder
Suspension
Polished LCAs
Rear camber kit
Shoes
Audio
Jensens Stereo
CONS
street_bliss
Nov 8, 2006 05:40 AM
