Thermostat
Old Nov 26, 2010 | 05:03 PM
chafetzk's Avatar
Default Thermostat
I have an 88 civic STD with a d15b1. Idk if the thermostat is opening because after I let it run and drive it a little the lower radiator hose where the thermostat is located remains cold(doesnt get hot). I have heat And when i changed the thermostat the heat got better, but the hose still doesnt heat up Does this mean the thermostat didn't open or is it supposed to be like that?
Old Nov 26, 2010 | 05:19 PM
FSRslug's Avatar
Default Re: Thermostat
Is the temp normal on the gauge?
Old Nov 26, 2010 | 06:10 PM
chafetzk's Avatar
It sits in the middle and doesnt overheat but idk because its cold here
Old Nov 26, 2010 | 07:06 PM
jdm ef8 89's Avatar
You put the thermostat in the right way with the dot pointing up.lol just a thought
Old Nov 26, 2010 | 10:21 PM
hatchet_honda's Avatar
you have heat...car doesnt overheat or run hot...whats the problem?
Old Nov 27, 2010 | 08:31 AM
chafetzk's Avatar
Its in properly and it's not really a problem I was jw because in most cars when it opens the hose gets hot
Old Nov 27, 2010 | 11:05 AM
freydaddy's Avatar
it actually takes a long time to get hot;
cools down quickly too.
Thank God for aluminum.
dbailey
11
Jan 30, 2020 04:27 AM
dlstech
16
Dec 12, 2012 03:04 AM
d16trexin
Mar 23, 2009 05:54 AM
E JAY 1
Apr 26, 2008 10:02 AM
Ludester
Jan 16, 2004 11:19 AM
