2.3-octane question
Old Nov 26, 2010 | 04:00 PM
Gunnar24's Avatar
Default 2.3-octane question
Does anyone notice a significant difference when you switch to 92 from 87?
Thanks!
Old Nov 26, 2010 | 08:03 PM
nus_dogg's Avatar
Default Re: 2.3-octane question
No. It will not give you horsepower gains. You can ruin your motor that way if I'm not mistaken. Its harder to burn compared to 87 if you're low comp. You'd only want 92 if you're High Compression because High Compression tends to detonate, so therefore, 92 will need to be used.
92 will not detonate before 87. Thats all it does is resistance to knock. 87 is good enough since you're low compression.
Old Nov 27, 2010 | 10:59 AM
Bwill9886's Avatar
Nus_dogg is correct that the motor was not designed to use higher octane gas for any reason. You will not see any gains from using it, and some motors will not perform as well.
The ONLY reason you should use premium in your motor is if you are tuned for it (running forced induction).
Just stick to 87 and add some injector cleaner every once in a while and you'll be fine.
Old Nov 27, 2010 | 04:42 PM
accord99power's Avatar
agreed use whats specified by honda.
Old Nov 28, 2010 | 12:10 PM
My02accord's Avatar
Wow someone that knows the right answer
95% of the people I see say (higher octane burns slower) which is False, it is only less resistance to knock. If it burned slowerrr why would you want to use it in a forced induction high revvinggg engine where combustions takes place so many times in a second? It would be worse because it wont have as much time to completely burn which would result in less power output.
Old Nov 28, 2010 | 03:13 PM
chikin pickle's Avatar
octane rating has nothing to do with the speed of combustion of gasoline. It is merely a scale that rates a fuels resistance to detonation when compared to a mixture of iso-octane and heptane (hydrocarbon chains). Essentially, the resistance to detonation of the fuel in question is measured against the resistance to detonation of the mixture. For example the detonation resistance of a gasoline that is equivalent to a mixture containing 87% iso-octane is 87 octane gasoline. But that number is only a comparison and does not have anything to do with the chemical composition of the fuel in question. Fuels with an octane number greater than 100 are more resistant to detonation than pure iso-octane.
And to the poster above me, not all forced induction engines are high-revving. All modern diesel engines are turbocharged, but most operate below 3500 RPM.
To answer the original question. Burning 92 octane fuel in an engine designed to run on a lower octane gasoline will not affect it's operation at all.
Old Nov 28, 2010 | 03:45 PM
My02accord's Avatar
[QUOTE=chikin pickle;44108902]
QUOTE]
True, I just threw that out there meaning most high performance engines are going to run higher than 87 whether it be high compressed or forced induction or spray. If someone is going to spend tons of money on a motor theyre going to run 92 to reduce any chance of pinging, to an extent anyway. I'm a diesel mechanic so I know they dont rev out high
Old Nov 28, 2010 | 03:50 PM
Balla just checking.
Old Nov 28, 2010 | 05:30 PM
george323's Avatar
Soo true..
Old Nov 28, 2010 | 05:46 PM
kageshin's Avatar
hate to say it.....our hondas won't react well to the higher octane gases simply because they are built with economy in mind hence the low compression engines........just do your tune up items per manufacture's recommended schedule.....and use the injector cleaners sparingly (i use once per year).....that should keep your car from breaking...barring accidents
Old Nov 28, 2010 | 11:01 PM
20-EM2-05's Avatar
People can say "When switching from to 89 after using 87 for such a long time, I feel more of a kick to it".
All piles of crap.
I've used 87 on my F23A1 (Requires 85 at the minimum) and when I tried to test out a full tank of 89. It didn't help squat. It actually made my MPG drop and cost me an extra 6 dollars.
Nus_Dog had the answer you need.
unknown0001
12
May 28, 2005 08:12 AM
JdM_Eg_6
Mar 18, 2004 09:26 AM
ErikDaGenErik
Jun 9, 2003 04:41 PM
99YZF
Jan 4, 2003 02:56 PM
InfamousRS
Apr 18, 2002 05:26 AM
