1989 CRX HF shell and other EF stuff
I need this stuff gone yesterday. I need to get some cash up quick. Had something unexpected come up.
CRX IS SOLD!
I have most, if not, everything to put the car back together.
I also have some other parts that can be sold separately.
Cable Si trans- Approx. 160K miles. Worked fine when it came out of a crx si. -$150
a few PM6 ecus-$20 each
non-vtec jdm d15b ( good clean motor. great for a stock replacement of any non-vtec d series. just throw your intake/exhaust manifold etc on it.) $300
Machined finish Rota Slipstreams 15x6.5 BRAND NEW still in the plastic -$350
OEM d16a6 rods with std bore ZC pistons-$75
D16a6 bare block-$40
d16a6 head-$40
d16a6 Crank-$30
I'd prefer local pickup. I don't really have time for shipping etc.
I'm located in Augusta Ga.
Thanks!
CRX IS SOLD!
d16a6 head-$40
d16a6 Crank-$30
Thanks!
Rods/pistons have not been run since assembled. The d15b is an obd2 motor. At the moment it has obd0 DPFI stuff on it. A guy installed it into an ef hatch and couldnt figure out why it wouldnt start ( it had a bad main relay) He didnt put any miles on it.. so I'd assume it has somewhere between 40K-100K miles. I have a Timing belt and water pump for it somewhere that could go with it.
I dont KNOW it runs but there is no reason it shouldn't. It turns over, the timing belt is intact..it has lower than normal miles and it's clean as ****.
Come get it today and you can take it for $250
706-631-8466 if you want it.
-Clayton
-Clayton
everything but CRX shell and Si trans still for sale......someone needs this stuff. no more hondas around the house. I have no use for this stuff.
OoThomioO
49
Jul 15, 2010 08:25 AM
sonic47
Mar 22, 2010 09:09 AM
FSTVTEC
Appearance Build Threads
37
Mar 22, 2009 06:24 AM
