73 Honda CB500 stalls
Old Nov 26, 2010 | 12:14 PM
asanjuan1's Avatar
Icon6 73 Honda CB500 stalls
Looking for ideas what may be causing my '73 CB500 to stall for a quick second when starting in 1st gear or 2 seconds after shifting into second gear? Acts like the key switch was turned off for just a milla second. It's a new(used) bike so I haven't made it to third or fourth gear to see if it occurs in the othrr gears. I'm thinking more on electrical side? Any thoughts?
Old Nov 27, 2010 | 05:14 PM
theedeadmau5's Avatar
Default Re: 73 Honda CB500 stalls
im thinking more on the fuel side, did the bike sit for a while before you bought it? if so, pull the carbs and check the floats to see if they are going back into place when the fuel is turned on. give them a good cleaning
drain the gas if you havent already and put fresh in.
check for blocked passages in the fuel cap venting.
the petcock screen may also be clogged from the old gas if it sat for a while. the screen is inside the fuel tank so i believe the tank needs to be removed and the petcock removed for cleaning. try not to break it.
dohcdelsol
Honda Motorcycles
16
Jan 25, 2009 12:14 PM
BusaWill
Honda Motorcycles
59
Sep 11, 2006 04:42 PM
kihun_cha
Honda Motorcycles
12
Mar 20, 2006 06:00 AM
99lspwr
Honda Motorcycles
Sep 17, 2003 05:11 AM
