will a 97 motor fit in a 98 accord?
Old Nov 25, 2010 | 09:48 PM
T.Y.SONNY's Avatar
Default will a 97 motor fit in a 98 accord?
not real familiar with accords, but will a 97 accord motor fit into a 98 accord? or will i have to swap out sensors? thanks for any help
Old Nov 26, 2010 | 08:00 PM
nus_dogg's Avatar
Default Re: will a 97 motor fit in a 98 accord?
The 97 engine has to be VTEC if its going to go into a '98 chasis, because all of the 98-01 Accord comes with VTEC for the 4cyl model Accord. I would just get another F23A1 engine, because you're downgrading it to a 2.2L while the original motor for the 98 chasis is a 2.3L engine.
Both engines are OBD2, so you're good on that cause the CKP sensor will be on the oil pump housing on both cars.
Old Nov 26, 2010 | 08:32 PM
92civlude's Avatar
The F23A5 used in the DX and value package Accord is non VTEC.
Old Nov 26, 2010 | 08:50 PM
nus_dogg's Avatar
That must be in UKDM. Here in the U.S, there's only the F23A1 and the J-Series V6 engines for the 98-01 Accords. I have yet to see an F23A5 in a 6th Gen Accord, and I have never seen a Non VTEC engine in a 98-01 Accord. The ones I've seen are all F23A1 SOHC VTEC.
Old Nov 26, 2010 | 09:18 PM
wolfy47's Avatar
sorry to burst your bubble nus but according to wikipedia
F23A5
This engine was used in the 1998-2002 Honda Accord DX and the 2002 Honda Accord LX VP (value package) in North America.
Specifications
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Valve Configuration: SOHC, 16 valves
Compression ratio: 8.8:1
Max power: 135 hp (100 kW) @ 5500 rpm
Max torque: 153 ft·lbf (206 Nm) @ 4500 rpm
but i agree dont downgrade, stick with the F23
Old Nov 27, 2010 | 12:37 AM
20-EM2-05's Avatar
To be honest... Here in california i've never seen any DX or VP 6th gen accords.
All I've seen are V6, LX, and EX.
Most people on 6thgenaccor doesn't even own a DX also. It's always LX or EX.
You forget there is the ULEV accord engine... Now what was that the F23A4?
Old Nov 27, 2010 | 10:30 AM
Bwill9886's Avatar
Nope, the F23a5 is USDM as well. 92civlude is correct in that is was only available in the DX and VP. You don't see many of these trims for the 6th gen, so you don't see many of these engines.
Besides checking out the link wolfy47 posted, you can look it up anywhere, and you'll see they definitely exist here.
Yeah like I said, you almost never see any 6th gens with the lowest trim. The F23a5 made like 135 hp and 152 tq so it wasn't too bad, but I'm definitely glad I have the extra power VTEC offers.
Yes, the ULEV was the F23a4 and made just a few less hp.
ANYWAY, back on topic. OP, are you choosing the 97 motor because of budget reasons, convenience, or what?
The motor will of course physically fit. Is your 97 motor the b1 or b2? Pretty sure the harness and ECU (if you still have them) in the 98 will work with the 97 motor even.
Old Nov 27, 2010 | 02:19 PM
T.Y.SONNY's Avatar
Thanks for everyones help, I greatly apperciate it!! I'm only going with the 97 motor because it's the only one I could find on island, (I'm from Hawaii btw). I'm just trying to help out a friend, his motor rod knocked and he needs the car asap!! Thanks for everyone help again
6KAOS6
Jun 23, 2011 07:45 PM
Mysterious
Dec 9, 2006 10:23 PM
shavedH22AKCL
Sep 9, 2005 06:38 AM
detlihonda
Feb 21, 2005 08:57 AM
TRiPPiE
Jan 20, 2003 05:48 PM
