Fs: b16 parts, buddy club cams, portflow, bbk, gsr, Cheap!
All parts are used and in working condition.
New Parts
B16 oil pan 40$ No dents, Clean
brand new obd2a b16/gsr dizzy 100$
Obd2 b18/b20 dizzy 75$
Aftermarket b16 intake mani 100$ (looks like blox maybe)
BBK 70mm tb (Has a broken piece around where the coupler goes.. great for n/a) 100$
B16/Gsr obd1 dizzy, aftermarket, great shape, worked fine, 100$
Gsr Rods. With pistons 1 is good. 40$
B series Flywheel is 30$
B series starter 50$
b16 crank pully 20$ with bolt/ keyway ect
b16 lmas and rockers and head (no vtec sol.)40$
for parts only, damage to # 4 combustion cyc (valve broke)
Vtec sol (Sold)
B series ek t bracket. rare 50$ clean
a/c compressor B series with mounts/ belt. was on SI. 50$
B16 crank spun #2 20$ can be turned
B16a2 block 100$
clean. has mains. needs oil pump new water pump.
B series idle air control valve. 20$
b18b1 /b2 or b20 Timing belt. New 20$
b16 ecu. 99-00 si (p2t) 80$
b20 intake manifold
Tons of parts for sale.
obd2 injectors 20$ a set
obd1 injectors 20$ a set
Tons of intake manifolds, B/d/ b20 long
More parts coming soon
Thanks Guys
New Parts
Vtec sol (Sold)
B16a2 block 100$
b20 intake manifold
Thanks Guys
Anyone know how to identify them?
i know they don't look like oem when i compared them to my stock b16 ones.
i'm not trying to pull anything all parts are legit but i understand your concern i do have most receipts but ill try and find something. i cant find how to identify them online. but ill tell you i know they arent oem. car had a mild lope. and aggressive mid rpm
Priced too low? i basically put my prices 50% of New saw they go for 480-600$
i have everything priced to sell. as you can see in the pics of the cams 1 of my valves broke in half at the drag strip. Forcing me to part out this motor.
the dual valve springs/tit retainers and cams were awesome. why the person slacked on buying aftermarket valves gets me.
they valve broke right at the stem where it meets the petal... just damaging my piston, and the combustion chamber part of the head
Im just saying. If you had proof that they are BC3's then I would of bought them myself. With all the dumb threads of Help Me Identify my Cams going around, I just dont want to be in that situation.
anyways GLWS on your other stuff
Again lets hope they are BC 3's it would of been a sweet deal
these are not gsr cams, they loped in my car, and you can tell from looking at them they have like low miles on them cause the edges of the lobe is very sharp. aka not oem cams.
haas480
Jun 8, 2009 08:06 AM
