Aftermarket LCA's with stock sway bar.. Input needed
This is on a 1994 Integra RS. I'm running buddy club lower control arm's with my stock integra rs sway bar.. These LCA's with my stock sway cause an issue of the sway bar bushings binding.
Now i'm considering upgrading to an ITR rear sway bar and would like to know how i can fix this.. Honestly i don't know much about it so if someone could point me in the right direction.. IE: if i need adjustable end-links, where to order, etc.
Thanks guys.
Thanks guys.
Here are some adjustable endlinks, I am currently runing blox front and rear without any issues. Well one, without the use of washers the endlinks will not be straight. No big deal really, just took some washers and a few minutes and everything is fine.
The only thing is, being they spherical's they will not last nearly as long as a OEM endlink would.
http://www.jhpusa.com/store/pc/viewC...idCategory=169
Your problem likely is the whole for the endlink isnt in the correct spot, if this is true, any of the endlinks above should take care of this problem.
Good luck.
Good luck.
Yes, I actually use them on my oem Si sway bar.
Im glad you asked that question, becuase then I remember, you may need to pick up spacers for the endlink end of the sway bar.
The hole on the itr bar is larger. This is based off of what im told, and read. ill look for a thread that explains it.
Function7 sells them I belive for 20ish bucks.
SiZ
Jun 4, 2006 12:44 PM
Dragger817
Dec 21, 2003 12:11 AM
